Passenger window
Old May 12, 2009 | 03:31 PM
GaryMcCullough's Avatar
Default Passenger window
I cleaned my negative battery terminal on my 2005 tc and now the passenger window won't work from the driver's side door. How do I get it to work again. Also, now the engine runs rough.
Old May 12, 2009 | 03:33 PM
rosedaleny806's Avatar
yeah its normal u have to program it again basically jus hold the button up till it goes up and then down to go down after awhile it will be programmed again, and if u have a moonroof do the same on that.
SATownScion's Avatar
need to reset the window, there are a few posts about this as well as in your manual if you still have it. i would tell you how to do it but i havent done it in awhile and dont want to give you bad info.
as for the engine, allow the ecu to reset it self, should clear up after awhile.
Old May 12, 2009 | 03:35 PM
i thought it was roll down to more than halfway and then hold the up button for 5 seconds after it fully closes.
Old May 12, 2009 | 03:40 PM
ack154's Avatar
https://www.scionlife.com/forums/viewtopic.php?t=59647
http://home.roadrunner.com/~icdedppl/faq.html#c14
This is also in the Owner's Manual.
prescottn
Oct 8, 2015 05:31 PM
Pack34
Scion tC 1G ICE & Interior
Sep 27, 2015 07:11 PM
Xaphoon
Sep 21, 2015 02:18 PM
prescottn
Sep 13, 2015 09:04 PM
BlingSlade
Sep 5, 2015 08:52 AM
