Passenger window
I cleaned my negative battery terminal on my 2005 tc and now the passenger window won't work from the driver's side door. How do I get it to work again. Also, now the engine runs rough.
yeah its normal u have to program it again basically jus hold the button up till it goes up and then down to go down after awhile it will be programmed again, and if u have a moonroof do the same on that.
need to reset the window, there are a few posts about this as well as in your manual if you still have it. i would tell you how to do it but i havent done it in awhile and dont want to give you bad info.
as for the engine, allow the ecu to reset it self, should clear up after awhile.
https://www.scionlife.com/forums/viewtopic.php?t=59647
http://home.roadrunner.com/~icdedppl/faq.html#c14
This is also in the Owner's Manual.
Pack34
Scion tC 1G ICE & Interior
Sep 27, 2015 07:11 PM
Xaphoon
Sep 21, 2015 02:18 PM
BlingSlade
Sep 5, 2015 08:52 AM
