Regional - Deep South AL, AR, LA, MS
AEM EMS tuning for Scion TC
Old May 27, 2009 | 05:44 PM
DezodDon's Avatar
Default AEM EMS tuning for Scion TC
If anyone is in need of Dyno Tuning for your Scion TC using our AEM EMS we are willing to travel.
Contact Paul for more details.
(I have some friends in the Biloxi, Gulfport area I'm looking to spend time with )
Old May 31, 2009 | 08:44 PM
SB08tc's Avatar
This link is a full build of my car. the thred is on importsnc.com
http://importsnc.com/forums/national...bocharged.html
this thread also has dyno sheets.
Old Jun 1, 2009 | 02:10 PM
DezodDon's Avatar
1. Where are you located?
2. I personally wouldn't have used washer fluid. However the problem with washer fluid is not that it contains water. The problem is that the mixtures of meth to water are inconsistent from bottle to bottle. It's never completely 50/50. Which is fine. Most meth pumps can't handle running straight meth. Seals wear out and the pumps fail etc. You are supposed to run a 50/50 mix of meth to water. Steam, not a problem. Also keep in mind you can tune off 100% meth with no problems you just need to tune accordingly. Either way. It sounds to me like a tune issue. Perhaps your meth tank ran low? Check it out.
If you have low compression on two cylinders I wouldn't be surprised to find cylinders 2 and 3 damaged. Make sure they check the head as well. These 2AZ-FE engines are not that good at resisting detonation.
Keep us updated to what you find.
Also I am not sure what kind of recourse you might have with a lawyer. There's alot of gray area there.
Old Jun 16, 2009 | 11:47 PM
RusWolf's Avatar
Don how does this travel tune works ?
I spoke to Kaizespeed from WA state and the owner who is the tuner quoted me $700 for AEM EMS tune.
Old Jun 17, 2009 | 04:52 PM
DezodDon's Avatar
Travel tune works like this.
Whatever travel costs are plus 150 an hour.
jdstC1
Jan 13, 2015 04:45 AM
TheTripleC
Jan 4, 2015 06:46 PM
AbsoluteRedtC
Dec 31, 2014 06:18 PM
minter66
Dec 15, 2014 01:45 PM
eric_m
29
Oct 12, 2003 08:22 AM
