S/C idler pulley fail
Old Jun 5, 2009 | 04:14 PM
Ghosty44's Avatar
Default S/C idler pulley fail
Has anyone with a S/C have their idler pulley fail on them? It is because mine failed the bearing inside is wiggling. I remove S/C thinking it had bearing failure on the shaft side found out my bearing fail on the idler pulley.
Old Jun 5, 2009 | 11:23 PM
TRDIZZLE's Avatar
dude i just had the same problem right now. and i went to the dealership and they dont sell just the bearing. its the whole assembly and they wanted $144 for it. i was like F that. so i used a 20 ton press and took the bearing out and took the pulley to carquest or any bearing shop and they will measure the inside of the pulley. and if you bring the stock bearing, they will measure that too. and i ended up only paying $12. and when i put it back in. there was minimal play. only reason for the extra play is cuz of the .003 in gap difference between the bearings. hopefully that works
Old Jun 6, 2009 | 02:33 AM
gompka's Avatar
You don't want to use crappy bearings, cause it will cause more damage. The bearings to use are $20 a piece, you don't need a press, a hammer will do. The part number is Koyo 6203-2rd-c3 should be available at any bearing place, or they will order it.
Old Jun 6, 2009 | 03:37 AM
TRDIZZLE's Avatar
for me it was just a temporary fix. its holding up for right now. especially throughout my beatings lol but i'll keep that part number in mind.
Old Jun 6, 2009 | 08:47 PM
Ghosty44's Avatar
Thanks for the information Gompka
Old Jun 6, 2009 | 08:48 PM
gompka's Avatar
no prob, the part number i posted is for 18000rpm bearings. Haven't had any problems for quite some time now
Old Mar 1, 2010 | 07:36 PM
ProMark's Avatar
so he whole pulley is wiggling ?
cuz mine is doing that too and i just called toyota and they said 99 for idler pulley, i assume that comes with bearing??
Old Apr 26, 2011 | 11:56 PM
novellaguitarist's Avatar
Yeah my idler pulley failed about a week ago. So much hassle with toyota tho. Went to my local dealer they said 99 dollars as well but i needed to pre-pay, so i did. Now today they called me and said TRD doesn't have the part in stock anymore so they are gonna figure out what they can do for me, whatever that means. I'm just getting irritated with the whole situation.
Old Apr 27, 2011 | 02:48 AM
AZGuy's Avatar
I had one fail on me too, just order the koyo bearing replacement for like 10 bucks. I went down to my local industrial shop and they had them in stock even. It is really easy to replace the bearing just a clip and it pops out. Toyota will sell you the entire assembly along with the hassle.
This is the part number I used, 62032RSC3. It is a pretty common bearing. Just looked on Amazon and its under 3 bucks there.
http://www.amazon.com/6203-2RS-C3-Be.../dp/B002HAX4J0
Old Feb 14, 2012 | 12:50 AM
gqdabien's Avatar
Anybody have instructions or DIY on how to replace these bearings on the s/c? Just bought a pair. Thanks!
Old Feb 14, 2012 | 12:51 PM
gompka's Avatar
It is pretty easy, you just need some snap ring pliers to take out the snap ring that holds the bearing in, then just tap it from behind and it will fall right out. It will be a PITA if you don't have the snap ring pliers.
Old Feb 14, 2012 | 02:06 PM
GammaTNT's Avatar
my 2006 sc idler pulley fail too. Got it replaced for $130( parts and labor)
Old Feb 15, 2012 | 08:26 PM
gqdabien's Avatar
Thanks Gompka, you seem to know the most about the S/C rebuild. I bought two pairs of bearings, 6203-2RS, and 6205-2RS. I'm guessing 2 go on the drive pulley end, and 2 go on the horseshoe shaft end. Which one is which?
I also bought a shaft seal, where does that go?
yupinmytC
22
Jul 27, 2024 07:08 PM
NonStopTuning
Scion FR-S Drivetrain & Power
14
May 5, 2017 06:52 PM
mudguy
Oct 22, 2015 04:31 PM
Scionxa180
Scion xA Aero & Exterior
Sep 24, 2015 10:58 PM
carbinefreak
Sep 24, 2015 02:06 AM
