will it work or rub
Old Jun 6, 2009 | 02:11 AM
elgueaga's Avatar
Default will it work or rub
will the tein springs which i believe are a 1.5 drop work with 18 inch rims .will this get rid of the wheel gap or will it rub on the fender?
Old Jun 6, 2009 | 02:19 AM
yeldak's Avatar
Which Teins? What width wheel? What size tire?
how about a
Old Jun 6, 2009 | 04:15 AM
AlanW's Avatar
I have 18's and running on S-Techs. I rub on some more abrupt hills or potholes but other than that, ordinary driving doesn't pose a problem. The springs are a bit on the soft side once you've properly broken them in and once they've settled. If you don't rub at first when you first put the springs on, you will eventually. Go with the H-techs if you want barely any rubbing with 18's. whether or not it rubs against the fender, you need to figure out your offset, if anything, when you get it aligned after you're dropped, tell them to put a little negative camber in the rear wheels if you have an offset that pushes the wheels farther out.
Jordly221
Feb 13, 2019 05:29 PM
scionlife
371
Jun 2, 2015 11:00 PM
wwotr
Mar 28, 2015 01:47 AM
meowtc
Mar 5, 2015 02:28 AM
Yakimaniac
Scion xD Wheel & Tire
Nov 22, 2014 04:20 PM
