Wobble in the back when making left turn
Old Jun 6, 2009 | 06:55 AM
midieval10's Avatar
Default Wobble in the back when making left turn
Hello,
Sorry for the noob question. When I make a left turn, I can feel a sort of "wobble" from the rear of the car when I finish the turn. What is that called? Is there a way to reduce that effect?
Old Jun 6, 2009 | 07:01 AM
BZinn1's Avatar
check your lug nuts,check your struts,any recent work to the car,is it lowered......????check the rear sway to see if anything is loose......
Old Jun 6, 2009 | 07:06 AM
midieval10's Avatar
This isn't a common thing? It's been doing it since I got it new. I haven't modified anything.
I have a Camry and it doesn't do this.
Old Jun 6, 2009 | 05:29 PM
BZinn1's Avatar
nope not comman,take it to the dealership and get it checked out,probably something loose soemwhere,it happens.
Old Jun 7, 2009 | 08:32 PM
sw09's Avatar
can be from an unbalanced wheel, excessive wear on parts of the tire (spots), damaged/loose suspension and/or wheel parts best bet is bringing it to the dealership and having them check it out
Old Jun 8, 2009 | 06:14 AM
midieval10's Avatar
This isn't the definition of "body roll" that I hear in the other threads? What is body roll and what kind of feeling does it give off?
Old Jun 8, 2009 | 08:08 AM
AlanW's Avatar
Body roll is basically the car tilting or leaning to one side from the weight transfer. Most cars shouldn't feel wobbly, the body roll is just leaning, not wobbling.
Old Jun 8, 2009 | 08:21 PM
skinnayyy's Avatar
Team Scionara
th easiest way to explain body roll is if you've ever been on a roller coaster.
When you go through a turn the rollercoaster takes the turn... but you swing to the outside of the turn... it's your car doing that.
Ferretgrrl
Oct 15, 2018 02:50 AM
mw1957
Jan 14, 2015 01:06 PM
cavalierkid888
Jan 8, 2015 04:42 AM
cid_mcdp
Jan 5, 2015 02:45 PM
George
Regional - Pacific South
200
Feb 11, 2006 01:48 PM
