very squishy brakes
Old Jun 10, 2009 | 07:40 PM
skakemokid's Avatar
Default very squishy brakes
So last night i was driving home and as i was getting off the free way, I went to push my brakes. and i literaly had push the pedal all the way down to floor to get any braking. First i thought i didnt have brake fluid, but its still full. Secondly i thought i busted a line. but they're still ok.
I was just wondering if this has happen to anyone?
thanks guys.
Old Jun 10, 2009 | 07:43 PM
matt's Avatar
if you had high speed braking episode earlier, you may have burned the brake fluid, in which case you need to bleed the brakes.
Old Jun 10, 2009 | 07:53 PM
ack154's Avatar
^ That's one option. Other option is if you left your foot on the brake pedal at all and "cooked" the brakes, you could have gotten them a bit hot before you tried to brake and then experienced a bit of brake fade when trying to actually stop.
Old Jun 10, 2009 | 08:03 PM
skakemokid's Avatar
it is possible i burned the fluid i was on the fifteen in excessive of speeds so its possible. i guess i got work to do. lol
and how could you tell if i cooked the brakes. i dont brake with my left foot. Actually thinking about it. LIke a month ago i changed my brakes and one side was more down the other. could that be an issues.?
Old Jun 10, 2009 | 08:05 PM
O5_TRD_tC's Avatar
ABS kicked in?
Old Jun 10, 2009 | 08:07 PM
ack154's Avatar
ABS kicked in?
You would be hearing/feeling that one. Trust me, I get it all of the time in autox.
If you changed your brakes a month ago, what did you change? Just pads? Maybe try to bleed the lines and see if that helps.
Old Jun 10, 2009 | 08:10 PM
rosedaleny806's Avatar
mines been like that for years now. brake pedal seems to be almost all the way down, i bled the brakes thinking it was an air pocket bc i pumped the brakes at a complete stop and i heard air but nope no air pockets when bleeding them, changed my rotors and pads and that wasnt the case either. i still have no clue what it can be im thinkin it could be a master cylinder or sumthing to do with the ABS module thingy but besides that my brakes are fine jus very squishy and very low
Old Jun 10, 2009 | 08:11 PM
O5_TRD_tC's Avatar
Originally Posted by ack154
ABS kicked in?
I hate ABS... lol
Old Jun 10, 2009 | 08:23 PM
TRDIZZLE's Avatar
ABS kicked in?
I hate ABS... lol
^ x2
Old Jun 10, 2009 | 08:39 PM
skakemokid's Avatar
Ok so its this is a normal prob. ill try bleeding them today to see if that helps. And when i did the brakes all i changed was the pads. But when i did one side was wore down more that the other. YOu think Maybe its stuck?
Old Jun 10, 2009 | 09:00 PM
O5_TRD_tC's Avatar
what it the right side? Its normal for the right side to be slightly more worn.
Old Jun 10, 2009 | 09:13 PM
skakemokid's Avatar
yeah its the right side. but seems like a crazy difference . its like the lifet is like I--- and right is I-
gqdabien
Oct 8, 2015 05:36 PM
Klashan
Sep 24, 2015 12:39 PM
DannyBoy65
Sep 21, 2015 06:23 PM
axB
Sep 18, 2015 06:11 AM
Subaru86
Scion FR-S Aero & Exterior
Sep 14, 2015 12:39 PM
