very squishy brakes
So last night i was driving home and as i was getting off the free way, I went to push my brakes. and i literaly had push the pedal all the way down to floor to get any braking. First i thought i didnt have brake fluid, but its still full. Secondly i thought i busted a line. but they're still ok.
I was just wondering if this has happen to anyone?
thanks guys.
thanks guys.
^ That's one option. Other option is if you left your foot on the brake pedal at all and "cooked" the brakes, you could have gotten them a bit hot before you tried to brake and then experienced a bit of brake fade when trying to actually stop.
it is possible i burned the fluid i was on the fifteen in excessive of speeds so its possible. i guess i got work to do. lol
and how could you tell if i cooked the brakes. i dont brake with my left foot. Actually thinking about it. LIke a month ago i changed my brakes and one side was more down the other. could that be an issues.?
ABS kicked in?
If you changed your brakes a month ago, what did you change? Just pads? Maybe try to bleed the lines and see if that helps.
mines been like that for years now. brake pedal seems to be almost all the way down, i bled the brakes thinking it was an air pocket bc i pumped the brakes at a complete stop and i heard air but nope no air pockets when bleeding them, changed my rotors and pads and that wasnt the case either. i still have no clue what it can be im thinkin it could be a master cylinder or sumthing to do with the ABS module thingy but besides that my brakes are fine jus very squishy and very low
Originally Posted by ack154
ABS kicked in?
ABS kicked in?
Ok so its this is a normal prob. ill try bleeding them today to see if that helps. And when i did the brakes all i changed was the pads. But when i did one side was wore down more that the other. YOu think Maybe its stuck?
Klashan
Sep 24, 2015 12:39 PM
