Unknown Engine Problem - Please Help Diagnose
Old Jun 11, 2009 | 08:26 PM
10gxiong's Avatar
Default Unknown Engine Problem - Please Help Diagnose
hi guys. i just brought my car back from the stealership spending $130 on a diagnostic and $109 on a cleaning service (similar to what people do using Seafoam). the reason i took the car in was because the engine shakes pretty hard when i'm in drive at a complete stop. the engine shakes so much that you even notice the windshield wipers rattling. the people at the dealership said they weren't able to repeat the issue so they want me to bring it in again. has anyone experienced this type of motor shaking with their tC? please help me figure out this issue because i don't want to be forking out money for no reason. thanks guys.
Old Jun 11, 2009 | 08:45 PM
ack154's Avatar
Low RPMs or what? What is it idling at?
Old Jun 11, 2009 | 08:55 PM
Macavely's Avatar
I don't know if this will help you be it helped me. Reset your ecm . You can do it by scan tool, If you don't have one then you can unplug you EFI fuse and crank you engine for 3 seconds. Or unplug your cars batt.... then go for a drive where the motor reaches proper operating temp.
Old Jun 12, 2009 | 12:25 AM
charlie07tc's Avatar
mine does, especially when the ac is on....but that's because i had the mounts replaced with polyeurethane inserts. check your motor mounts.
Old Jun 12, 2009 | 12:35 AM
RA042726's Avatar
MN Scions
Have you done anything to your engine at all? or any mods in general under the hood
Old Jun 12, 2009 | 01:24 AM
10gxiong's Avatar
the engine is all stock. i had a k&n oem replacement filter on for about 3,000 but took it out. the engine idles at about 800-900rmps when i'm at at stop. again, my car is an automatic. the car has about 56,000 miles on it.
Old Jun 12, 2009 | 01:32 AM
RA042726's Avatar
MN Scions
I'd take a look at your motor mounts. might be a possibility.
I've read some stuff too about a a loose idle tensioner pulley.
does it go away when you start driving?
Old Jun 12, 2009 | 03:26 AM
10gxiong's Avatar
yes, the motor shaking goes away after i start driving.
Old Jun 12, 2009 | 03:34 AM
kang2323's Avatar
Do you still have warranty??
If you don't have any mods then it's def a motor problem that warranty should cover.
Old Jun 12, 2009 | 04:47 AM
draxcaliber's Avatar
it really isn't a question about whether or not the warranty coverage is in effect, but the problem is duplicating the problem and getting the dealership to acknowledge it and diagnose and repair the problem.
Old Jun 12, 2009 | 05:02 PM
10gxiong's Avatar
yes, the car still retains the powertrain warranty, but like draxvaliber said, its not the warranty that matters. what matters is whether or not the stealership could replicate the issue. it seems like they weren't able to, so i'm going to have to take the car back in on saturday. could the belts possibly be what's causing the problem?
Jordly221
Feb 13, 2019 05:29 PM
RayScionXB
Regional - Pacific South
19
Mar 5, 2015 08:22 PM
RayScionXB
Regional - Everywhere Else
Mar 3, 2015 08:27 PM
cid_mcdp
Jan 5, 2015 02:45 PM
fluxingnation
Dec 26, 2014 04:28 PM
