I'm lost and stuck with spacers :(
Old Jun 12, 2009 | 09:50 PM
ToyoXrsPl's Avatar
Default I'm lost and stuck with spacers :(
So rims got delivered (Axis Oldskool 15x8 +25) and searching around I came to conclusion that they'll either fit tight or not fit at all cuz of calipers. so I ordered 5mm wheel spacers for front and 10mm for back just in case they don't fit.
So I put the wheels on and there's like 1mm space between the caliper and back of wheel, I can put a knife between, wheels spin without rubbing caliper but I'm scared cuz they'r so close.
So I go and try to install the spacers with reading some how to's on scionlife and I can't remove the front rotor for ____, I hit on it for 30min with a rubber mallet and nothing I also came to conclusion, that I have no clue where to even start with the back they'r not hub spacers in back, just normal ichiba spacers all around.
First mechanic I called wanted $180 to change all 16 bolts, so I gave up on that too, broke at the moment
I just gave up, declared myself beaten, and need some ideas. (installings springs was a walk in the park compared to this )
Old Jun 12, 2009 | 09:57 PM
maximthegreat's Avatar
grind the calipers
Old Jun 12, 2009 | 09:58 PM
RedneckwithanxB's Avatar
Stupid question #1. Did you pull off the caliper to get the rotor off?
You can replace the lug studs without removing the plate from the car, if you look at the back of them there is a little indentation on the backing plate that allws them to pop out and be replaced... just make sure you throw a factory lug nut on there and tighten it down so that it presses into place before you put the rotor back on... for the rear I believe all you have to do is remove the face of the drum, not to sure, never broke a rear stud...
Old Jun 13, 2009 | 05:31 PM
brownfaux's Avatar
Utah Scions
why didnt you get hub spacers for the back? After reading this I am going to go with ichiba up front for my og sans when i get them just for offset help. is it best to do the same for the rear or will my hub spacer be ok?
sorry, wish i could help you more on the problem, i read the diy, sounds like it just takes patience,
Old Jun 13, 2009 | 05:58 PM
ihatemyxa's Avatar
i dont think that the rim will touch the caliper, if what im thinking is right. go for a drive and find out! and you can get some spacers anywhere nowadays. and learn to change the studs yourself im sure there is some one local to help you
Old Jun 14, 2009 | 07:37 PM
brownfaux's Avatar
Utah Scions
dont forget about the guy who put new brakes on and then gouged the inside of his wheels because the caliper stuck out further.
ruzzzell
Scion xB 2nd-Gen Wheel & Tire
Oct 11, 2015 04:18 PM
terrye
Sep 26, 2015 12:24 AM
SJMiller
Sep 12, 2015 06:33 PM
BlingSlade
Sep 5, 2015 08:52 AM
paisatronix
Sep 5, 2015 04:13 AM
