Help with somewhat confusing subwoofer wiring
Old Jun 20, 2009 | 03:33 AM
Glowbox's Avatar
Default Help with somewhat confusing subwoofer wiring
I have two 4 ohm DVC Kicker CVR's in a sealed box woth two sealed chambers so i can't wire them together. i was wondering if i wire each sub to 2 ohm's and plug both subs into a mono amp will the amp load be 2 ohm's?
Old Jun 20, 2009 | 03:38 AM
rangerryda's Avatar
go to crutchfield.com for sub wiring info. it's all there.
Old Jun 20, 2009 | 03:10 PM
CanxB's Avatar
This will answer all your subwoofer wiring needs!!!!!!!
http://mobile.jlaudio.com/support_pages.php?page_id=145
Check the other sections about how all the different systems and boxes work.
http://mobile.jlaudio.com/support_pages.php?page_id=141
I found this and now I refer to it all the tme.
Old Jun 20, 2009 | 06:22 PM
Glowbox's Avatar
BOth the websites show the subs wired to each other and my box has two sealed chambers so i can't
Old Jun 21, 2009 | 01:57 AM
CanxB's Avatar
I just checked the wiring for your 2 x DVC 4 ohms and if you were to wire them in Series/Parallel you would get a 4 ohm load and if you were to wire in the Parallel/Parallel you would get a 1 ohm load.
So I guess the answer to your question would be no!
Old Jun 21, 2009 | 02:51 AM
rangerryda's Avatar
My suggestion is to "mate" the two boxes together and eliminate the terminal cups or add another cup to each box, one for each voice coil. It will look messy but it'll work. Otherwise, just buy a new box. They're not expensive.
dltjdgns66
Scion tC 1G ICE & Interior
Apr 15, 2015 07:59 AM
herwig
Mar 23, 2015 04:19 AM
NewBox06
Feb 3, 2015 12:36 PM
tc_Jake
Dec 31, 2014 01:45 AM
sithscripter
Mar 31, 2004 04:02 AM
