NST sc pulley install ?
Old Jun 22, 2009 | 10:10 PM
dwn4cause's Avatar
Default NST sc pulley install ?
I searched around but couldn't find a DYI for the NST pulley install. I know its some what simple lose the tensioner and the belt should be able to come off and then take off the old pulley bolt and install the new pulley and belt and tight the tensioner. But what direction to turn the tensioner (stand in front) towards car or front bumper and whats the tighting specs? Any information would help. Thanks
Old Jun 22, 2009 | 10:16 PM
jonathan110987's Avatar
pull towards teh bumper...im 95%sure...
make sure u have something to hold the pulley as you are removing the bolt that holds pulley, i used teh oil filter remover tool, wrap around the pulley to hold itfrom spinning.
Old Jun 23, 2009 | 04:10 PM
GammaTNT's Avatar
while u stand in front of the car. Pull the tensioner bolt towards you to loosen it
Here is a pic of the tools i use to remove the bolt.
I used: sandpaper, oil filter remover (the strap type) and my 1/2 inch belt remover to hold the pulley from spinning
(i don't recommend using the belt remover, because they are really weak, I broke 2 of them)
Now i got myself a nice 1/2 breaker bar .
Took me like 4 tries to loosen the bolt the first time,
When u install it, just warp the pulley the reverse direction.
done
Old Jun 23, 2009 | 05:07 PM
thats what i used to hold the pulley
Old Jun 26, 2009 | 12:54 AM
gompka's Avatar
even a battery powered impact gun will get it off, easy as butter, no need for these weird contraptions lol.
Old Jul 12, 2009 | 08:44 PM
SoulXquisite's Avatar
what about those anti tamper bolts? what do i need to use to take it off?
Old Jul 12, 2009 | 08:48 PM
mine didnt come with a tamperproof bolt.. most ppl cut them off and then find a new bolt for it or u can make your own key for it..
Old Jul 12, 2009 | 09:45 PM
b52hDUNN's Avatar
sears/ craftsman has a strap wrench that works well!
Old Jul 14, 2009 | 04:03 AM
dwn4cause's Avatar
Default installed
well i installed the pulley last week, I recommed using a 6 point 19mm socket for the tensinor.. the person who install the orginal kit almost stripped the bolt. Otheriwse everything worked out good, However I only seem to be getting around 8 psi i have the forge valve maybe the red ( i think)spring is to hard?
Old Jul 14, 2009 | 04:56 AM
gompka's Avatar
Default Re: installed
having the spring too hard won't make you loose boost, having one too loose may leak boost.
Old Jul 15, 2009 | 06:46 PM
BLUEMEANIE's Avatar
Team Hamster
I had three spacers on top of the red spring in my 007. I was hitting 10lbs at red line.
Old Jul 24, 2009 | 02:40 AM
game-over's Avatar
What do you mean by "spacer"
I have the 007 also and of came with three springs.
Sorry if it's a dumb question
Old Jul 25, 2009 | 03:27 AM
imsonofagun's Avatar
The spacers may look like washers. They're inserted with the spring to compress the spring, which provides more tension. It's like using a stiffer spring.
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
NonStopTuning
Jan 20, 2015 05:20 AM
TheTripleC
Jan 4, 2015 06:46 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
