Important question on Weapon R s/c intake?
I have an 07 tc with a s/c and 9.5psi pulley with the trd reflash of course. I want to get the Weapon R intake for it but people are telling me that the car will not run good and will run very lean and i might blow something up b/c of it unless I get a piggyback and get it tuned. Is this true or can i by this intake and just bolt it up and be good to go? thank you
Yes its true, however some people have installed an air and fuel gauge and seem to be getting good enough numbers, so if you must I would get an A/F gauge first, then put the intake in and see what you read, then you'll have the choice of leaving in or taking it off.
you need a piggyback tune because at WOT, your a/f ratios will get alittle lean. so it is much easier and safer to just get some tuning done (which will also net a nice gain in whp) than it is to just bolt it on and take your chances.
he is asking specifically about the weapon-r intake, you aren't using the weapon-r intake, so it isn't quite the same thing. the weapon-r intake, when it came out, they released dyno's with A/R's and they were alittle lean for most people's comfort.
I had the Weapon R s/c intake. WOT was OK since the MAF doesn't play as huge a role. Normal driving was terrible. Trying to maintain speed or light throttle and the AEM A/F gauge would read off-the-scale lean "---" and the car drove like crap. As soon as I stomp on the gas everything went back to normal, until I try to maintain speed.
https://www.scionlife.com/forums/vie...ntake&&start=0
the dyno's aren't there anymore, but people were arguing that 14.7 is "damn near perfect" while others were saying that anything over 12.5 to 13 is dangerous etc etc.
I think before i get the intake i am going to get an air/fuel gauge to see what im running at now. Then i might try to find a cheaper one like you said and see how it is.
When you say you gave your intake to someone else and it ran fine did it still run lean and just good or were the af/r's also good?
As far as I know he didn't have any A/FR problems. He doesn't have the car or intake anymore though.
Most of the time tuning is for WOT. I was seeing problems when trying to maintain speed or during light throttle.
If the tuner is using a dyno like Dyno Dynamics he should be able to test the tune at light to partial throttle while on the dyno.
I can see where you're coming from. Not sure if there would be much of a difference. Something else to think about is how the length of the intake tubing could affect performance. I look at it like drinking through a short straw compared to one of the "crazy straws" and how it takes more effort to move the same amount of drink with the longer straw. I know it makes a lot bigger difference with turbos, but would imagine it could affect performance on a supercharger.
