Road Noise
Old Jun 29, 2009 | 09:28 PM
NYNCTC's Avatar
Default Road Noise
For the last month or so i have been hearing a lot of noise from my tires. I can't really tell you how loud because i have nothing to compare it to, but with the windows closed i can hear the rotations. My question is, what do you think is the problem. I just put new wheels on today, so it isnt the wheels. Thanks for looking.
Also, the car is in desperate need of an alignment, but i want to wait until i do coilovers to that.
Old Jun 29, 2009 | 10:00 PM
ScionJim23's Avatar
What tire are you running. I know when I had my Kumho's the road noise was so loud that I though something was wrong. Switched to Vredestein tires and there is almost zero noise. Other thank a possible tire out of balance on the wheel, it could just be an alignment is needed.
Old Jun 29, 2009 | 10:02 PM
08Supawhite's Avatar
Also, how is your tire pressure? Generally, the higher the tire pressure, the louder the road noise.
Old Jun 29, 2009 | 10:05 PM
NYNCTC's Avatar
tires are the stock potenza's i think. also the tire pressure is fine. It may just be because it is like 100 here and they are getting low on tread and i need an alignment.
Old Jun 29, 2009 | 10:07 PM
09tC_CB7's Avatar
If you have new wheels, and you put new tires on it, I bet the issue is with the tires. I know this from my other cars, the tires can make a big difference in ride, noise, and responsiveness.
PS Go get the alignment and save your tires. The $50-$60 now is better (and cheaper) than replacing your all of your tires later.
Old Jun 29, 2009 | 10:13 PM
NYNCTC's Avatar
i put new wheels on, the old tires. I am doing my coilovers on friday, but i may get an aligment before then now just to see if i can rule that out.
Old Jun 29, 2009 | 10:15 PM
Humm... That's interesting because per every about 2 degree increase in temperature, road noise could decrease by as much as .1 db. Maybe it is just the combination of low tread and suspension malalignment or even tire choice like mentioned above.
sccarally
Regional - Lonestar
Aug 21, 2015 02:58 AM
javio24
Aug 13, 2015 05:27 PM
Marialzga
Jul 31, 2015 05:38 PM
Subaru86
Jul 31, 2015 04:33 AM
TinmanTC
Jul 12, 2015 07:53 PM
