oem brake help
Old Jul 8, 2009 | 03:44 AM
Sciontized's Avatar
Default oem brake help
for some time now on my '06 TC, I question the dealer saying that my brakes are fine, but i have this problem. Whenever i park on a hill or even a slightly slanted hill and use my e-brake, my brakes make a grinding noise and my car abrubtly rolls a little. The noise sounds like if you have the e-brake up and try to start rolling, it makes that grinding noise. This happen about a year and a half after i bought the car brand new. Any ideas?
Old Jul 8, 2009 | 04:32 AM
06scionbhs's Avatar
hmm id say check your pads? make sure there is good life on em...but a lot of the time a grinding sound is because of the rotors. may be worn out time for some new ones?
Old Jul 8, 2009 | 09:41 AM
sciontc_mich's Avatar
Default Re: oem brake help
sounds like your e-brake isn't adjusted tight enough for the 6-9 clicks when you pull up on it for it to stop the car from rolling. The e-brake at the rear brakes needs to have 1-3 more clicks applied to them from where they are adjusted now.
But the safest is to do a search on how to adjust them, do NOT adjust the e-brake at the handle, ALWAYS adjust it at the rear brakes.
Dealer obviously is being lazy giving you the old tired line of "it's okay"..
Old Jul 15, 2009 | 03:45 AM
07_Tc_blacksandpearl's Avatar
Not bashing you but pads and rotors have nothing to do with the e-brake. The e-brake style for tc's are drum in hat, which means there is a small drum brake inside the hat of the rotor, that is there strictly for the parking brake. You should do major adjustments at the assembly itself (I believe the rotors have to be removed) but fine tuning can be done at the e-brake handle. ( I dont know if you can adjust the e-brake at the handle of the tc or not, to be honest). If you need help adjusting the e-brake and the dealer refuses to do it unless you pay, pm me and I'll see if I can't help you out.
bluemex
Jun 16, 2015 03:22 AM
TotalChaos
Apr 7, 2015 09:02 PM
mc1114
Mar 11, 2015 02:34 AM
mischman
Jan 14, 2015 06:07 PM
TheTripleC
Jan 4, 2015 06:46 PM
