Steering wheel control help(anyone whose gone back to stock)
Old Jul 19, 2009 | 10:09 PM
dave2610's Avatar
Default Steering wheel control help(anyone whose gone back to stock)
I had to reinstall my oem head unit cause someone tried to steal my d3 and damaged it. I had a PAC swi control for the d3 but removed it now the steering wheel controls don't work with the oem headunit
Old Jul 19, 2009 | 10:21 PM
O5_TRD_tC's Avatar
did you reprogram it?
Old Jul 19, 2009 | 10:28 PM
dave2610's Avatar
How do you do that
Old Jul 19, 2009 | 11:12 PM
O5_TRD_tC's Avatar
theres a sequence require to enter the programming mode and more sequences for programing the functions.
Old Jul 20, 2009 | 12:26 AM
dave2610's Avatar
do you know what it is? Where can i find it?
Old Jul 20, 2009 | 03:10 PM
dave2610's Avatar
anyone
Old Jul 20, 2009 | 08:06 PM
Rebeld321's Avatar
make sure the aftermarket SWC module is completely uninstalled. Wiring behind the radio should look 100% factory. if you left anything in there, chances are that is what is causing it not to work.
there is no programing required, the oem radio should automatically respond.
Things to look for:
When the SWC module was installed some wires were cut, make sure all the wires are reattached correctly. Also some wires were wired together, so make sure they are now separated.
Make sure there is no non factory wiring still attached to the any of the smaller plugs behind the radio.
lastly, make sure all the plugs behind the radio are plugged all the way in. sometimes they appear to be all the way in but remember that sometimes looks can be deceiving.
I believe if you follow these tips, you will get your swc working again.
Old Jul 21, 2009 | 05:10 AM
SquallLHeart's Avatar
you plug the connector back in?
alan.. you fail. you can't reprogram something that's not there... he's talking about the OEM headunit..
fur_pig
Mar 20, 2020 04:28 PM
meowtc
Mar 5, 2015 02:28 AM
mischman
Jan 14, 2015 06:07 PM
Beesh
Jan 9, 2015 06:30 PM
armyrockmorales
Dec 28, 2014 10:39 PM
