2005 scion tc engine knocking
Old Jul 20, 2009 | 06:58 AM
naptownballer's Avatar
Default 2005 scion tc engine knocking
i am haveing some weird noise come from my engine i have a 2005 tc supercharged 9.5 pully the noise comes in a 3k rpms and dies off after 4500k any ideas i just put on headers and replaced the gasket so not an exaust leak i am also running a weapon r supercharger cai plz help
chould it be rod bearings?
Old Jul 21, 2009 | 03:25 PM
07_Tc_blacksandpearl's Avatar
Were going to need more info than just "a wierd noise" here and there. Some things you should probably share:
What gears? 1st? 5th? All?
How hard of acceleration? almost none, full boost?
Did it start right after you installed the headers?
What kind of noise is it? Rattle? Grinding?
Tuning? Who done it?<- lol, standalone? Stock dealer tune?
I'd also like to know if the car makes this noise sitting at a stop at 3-4.5k rpms. Have someone sit inside of the vehicle and rev it up. If you hear the noise pop your hood and try to find where it is coming from.
Old Jul 21, 2009 | 03:31 PM
draxcaliber's Avatar
you are using 91 octane minimum right?
Old Jul 21, 2009 | 04:25 PM
all gears
dosent matter just a 3k to 4.5krpm
yes
knocking
fully tuned piggyback
and yes sitting u can hear it at 3k rpms
Old Jul 21, 2009 | 04:27 PM
yes i am not stupid but is it not 93?
Old Jul 21, 2009 | 04:30 PM
91 is the minimum, but most gas stations seem to have 93 octane.
just thought i'd check.
did you get the trd reflash? or did you only tune with a piggyback on the stock ecu?
do you know your a/f when it is knocking?
Old Jul 25, 2009 | 04:14 AM
Drax has a good point. I'd definitely check your afr's during the knock. Also, is the engine pulling timing at all because of the knock? See if you can datalog and get some more info from the sensors.
Old Jul 26, 2009 | 01:41 AM
garynkim's Avatar
check your belt tensioner.. see if that is messed...
AbsoluteRedtC
Dec 31, 2014 06:18 PM
lunchbx05
Dec 29, 2014 07:53 PM
minter66
Dec 15, 2014 01:45 PM
eric_m
79
Mar 17, 2013 12:21 AM
tC_Normo
Oct 22, 2003 07:20 PM
