trans cooler for auto question
Old Aug 13, 2009 | 02:26 PM
krazyjvilled's Avatar
Default trans cooler for auto question
anyone know if this improves time on the quarter mile... i would not think so but i did a search on here and someone claimed they were running 15.9's and then put this on their auto and got to 15.6's.... does it have that much of an effect or is this bs like i suspect?
Old Aug 13, 2009 | 03:33 PM
bdis3's Avatar
No, its not bs. Your trans wont hesitate to shift. You will definitely loose time off your 1/4.
Old Aug 13, 2009 | 04:08 PM
paul_dezod's Avatar
Scionetics
KAD
I am not sure about better 1/4 times, however it will definitely help prevent trans failure.
Old Aug 13, 2009 | 05:08 PM
vettereddie's Avatar
Are you turbo? It's pretty much a necessity there. If not, you probably won't need it, though it won't hurt and will prolong transmission life. The B&M supercooler is a cinch to install, just two hoses routed in line after the stock oil cooler in the radiator.
Old Aug 13, 2009 | 05:11 PM
paul_dezod's Avatar
Scionetics
KAD
Speaking from experience here^^
Old Aug 13, 2009 | 06:10 PM
bdis3's Avatar
I was thinking valve body. MY bad.
Old Aug 13, 2009 | 07:24 PM
no im not turbo, but i do shoot nitrous...
so basically it will NOT help the quarter mile time then? anyone got a link to a valve body upgrade or know the general cost for something like this... how about a torque converter for autos?
Old Aug 13, 2009 | 10:21 PM
tcchris38's Avatar
Here is the link for everything that you will ever need for your trans.
http://www.importperformancetrans.com/toyotaauto.shtml
These guys have the best prices around.
Cost for a valve body is about $600
Old Aug 14, 2009 | 02:11 PM
How do they compare to Level10? Haven't heard of them before but price definately looks better. Here's level 10 for comparison.
http://www.levelten.com/
Old Aug 14, 2009 | 04:04 PM
which one on the IPT website is the valve body upgrade for the tc? is it the toyota FWD where it says if u cant find the shift kit for ur car click here lol?
Old Aug 14, 2009 | 04:09 PM
and on the level10... which is the valvebody for our car? is it this one? http://www.levelten.com/Level_10_Toy...a210-5000p.htm
cuz i dont see our engine listed... but if it is the above... wow it says it shifts faster than a manual...
Old Aug 14, 2009 | 04:15 PM
also.. which would u guys recommend doing first for the auto transmission... a torque converter or the valve body upgrade? which will make the better improvement on the quarter mile, and would a trans cooler be required for either?
thanks for the answers guys
Old Aug 14, 2009 | 06:16 PM
Nightbeat's Avatar
valve body upgrade all the way, makes the shifts alot cleaner
Old Aug 14, 2009 | 07:06 PM
hmm.. asked a couple friends and they said torque converter first lol.. guess its just preference...
anyone know the timetable it takes to get thse back when u send them in to level10 or ipt? it sucks having to wait and not be able to drive my car
Old Aug 14, 2009 | 08:26 PM
Those are all transmission models, not engine model numbers. If you're not turbo, you don't need the upgraded torque convertor. It allows you to run higher RPM at launch, but the tC already has good low-end torque and you don't have a turbo to spool. You'll only see benifit on higher than stock horsepower applications where the power band gets shifted to the upper end. A valve job will be noticable even on a stock engine and give you a quicker shift.
Old Aug 14, 2009 | 08:27 PM
If you're worried about down time, buy a spare used transmission. It's getting rebuilt anyway. http://www.car-part.com has them starting at $400. Build the spare and then you're only down for the install time.
Old Aug 14, 2009 | 09:45 PM
svrTc06's Avatar
does doing the valve body upgrade shorten the life of the transmission at all??
Old Aug 15, 2009 | 05:21 AM
tcchris38's Avatar
I dont see how the valvebody would shorten the life of the trans.
Usally if you get your valvebody to IPT they try to get it out the same day they recive it if it gets delivered in the morning. If they are expecting it once they recive it they jump right on it becasue they understand that we need our cars. I had mine sent there done and back to me within three days.
The valvebody makes a very big difference. I know I added a 2.5 s-pipe and the valve body and on the base dyno run I gained a total of 20 WHP.
I would say the valvebody is deffently more important thing to do first. Also we have the 241 trans just so you know.
Old Aug 15, 2009 | 01:45 PM
bdis3's Avatar
Chris. When we going to the track? your 261whp vs my 258whp.
Ill go on street tires too.
Old Aug 15, 2009 | 07:13 PM
the torque dampener would benefit nitrous applications no?
