5.25 and 6.5 inch speaker install.....hard? MDF rings?
Old Feb 2, 2005 | 04:33 AM
chambox's Avatar
Default 5.25 and 6.5 inch speaker install.....hard? MDF rings?
Im installing Infinity kappas throughout the Xb. 4" in dash 6.5 in door and 5.25 in the rear. Ive been reading alot about installation and i was wondering how hard this will be.
4" i just drop them in and trim some of the plate
BUT
the 6.5 and 5.25, how hard will install be? Do i have to make MDF rings or mod some plastic? Or will they just drop in? Please tell/show me how u did it.
IF anyone has pics of install or how to make MDF rings please help.
Old Feb 2, 2005 | 07:18 AM
SuperCrunchyAction's Avatar
You can cut the stock speakers out and mount the new speakers in their location. You can always drill the rivets out and use your own spacers too.
Old Feb 2, 2005 | 03:33 PM
VtScionGuy's Avatar
Yes drill out the rivets with a bit and then use a jigsaw($30) to cut out some 1/2" or 3/4" MDF rings. Use Self-tapping ground screws to get through the metal. Might want to predrill the holes a little bit too.
Also why put 4" speakers up in the dash for? I doubt it'll sound good besides adding more volume. I personally put like a 3-4 inch tweeter there. =P
Old Feb 2, 2005 | 03:46 PM
squirrel's Avatar
For my front dor 6.5s, I drilled out the rivets, and used MDF rings to mount the Ground Zero co-axials.
Old Feb 3, 2005 | 02:17 AM
Sciond's Avatar
has anyone put 6.5's in the back?
Old Feb 3, 2005 | 02:30 AM
DenZinz's Avatar
scosche (www.scosche.com) sells adapters for the xB. This one happens to be for the rear.
http://scosche.com/scosche.aspx?Cate...temID=SASCN656
Old Feb 3, 2005 | 02:38 AM
BigOrangeXb's Avatar
Is that adapter for putting 6.5's in the back? It doesn't say anything on the site.
Old Feb 3, 2005 | 02:41 AM
DenZinz's Avatar
no sure...by the looks of it. maybe only a 5.25. A 6.5 would consume the factory mounting holes.
Old Feb 3, 2005 | 12:57 PM
SCI_TC_GUY's Avatar
I'm sure with enough will there would be a way to do it.....
Old Feb 3, 2005 | 01:04 PM
dgHotLava's Avatar
you can put 6.5's in the back. you will need to trim the metal where it mounts.
for the fronts i used 1 inch MDF (have a very deep speaker)
Old Feb 3, 2005 | 05:28 PM
DenZinz's Avatar
Yes anyting is possible. If you want to cut the metal to add a bigger speaker it will work. I was just refering to the adapter. IMO, speakers back there are a waste, you are better off adding speakers in the rear door if you need rear fill.
Old Feb 3, 2005 | 06:47 PM
dgHotLava's Avatar
agree, i start with whats there. then i add as needed...
Old Feb 4, 2005 | 04:15 AM
Sciond's Avatar
yep
Old Feb 4, 2005 | 04:28 AM
flowmini98's Avatar
i dont know ____ bout wiring...how hard is it to wire up new speakers with the stock wires..?
Old Feb 4, 2005 | 05:12 AM
DenZinz's Avatar
Pretty simple, you can either splice it or go to best buy and get the speaker harness for them. just plug them in and your ready to go.
Old Feb 5, 2005 | 09:01 AM
ugly_duck's Avatar
has anyone modified the rear speakers to accomadate a set of 8" woofers? I know JL makes a 6.5 sub that is pretty good.
Old Feb 6, 2005 | 03:42 AM
Sciond's Avatar
hmm that is a good question as I have 2 8" subs sitting aound the garage
Old Feb 6, 2005 | 04:48 AM
Notacop's Avatar
I ended up getting speaker adapters from crutchfield, they claimed for 5.25's but they fit the 6.5 infiniti kappa perfect midbasses fine in the doors. The only problem is they stick out far enough that I could not get the bottom of the door panel to snap back into place, but it is truly not noticable (and I am pretty picky)
Old Feb 6, 2005 | 01:44 PM
tbone587's Avatar
notacop u could fix the door panel not snapping back in at the bottom. All you do is pop out the door panel again, and look at the back of the speaker grille on the panel. There will be a ring that is sticking out. Cut this off with a utility knife or scissors and the panel will sit flush.
Old Feb 7, 2005 | 06:33 PM
Notacop's Avatar
sweet, thanks for the help!
yupinmytC
22
Jul 27, 2024 07:08 PM
rvascion
Nov 12, 2020 03:23 AM
Mjdavis1994
Sep 21, 2015 04:42 AM
Btp907
Sep 15, 2015 02:54 AM
Subaru86
Scion FR-S ICE & Interior
Sep 10, 2015 08:11 AM
