5.25 and 6.5 inch speaker install.....hard? MDF rings?
Im installing Infinity kappas throughout the Xb. 4" in dash 6.5 in door and 5.25 in the rear. Ive been reading alot about installation and i was wondering how hard this will be.
4" i just drop them in and trim some of the plate
BUT
the 6.5 and 5.25, how hard will install be? Do i have to make MDF rings or mod some plastic? Or will they just drop in? Please tell/show me how u did it.
IF anyone has pics of install or how to make MDF rings please help.
BUT
Yes drill out the rivets with a bit and then use a jigsaw($30) to cut out some 1/2" or 3/4" MDF rings. Use Self-tapping ground screws to get through the metal. Might want to predrill the holes a little bit too.
Also why put 4" speakers up in the dash for? I doubt it'll sound good besides adding more volume. I personally put like a 3-4 inch tweeter there. =P
scosche (www.scosche.com) sells adapters for the xB. This one happens to be for the rear.
http://scosche.com/scosche.aspx?Cate...temID=SASCN656
Yes anyting is possible. If you want to cut the metal to add a bigger speaker it will work. I was just refering to the adapter. IMO, speakers back there are a waste, you are better off adding speakers in the rear door if you need rear fill.
Originally Posted by flowmini98
i dont know ____ bout wiring...how hard is it to wire up new speakers with the stock wires..?
Originally Posted by ugly duck
has anyone modified the rear speakers to accomadate a set of 8" woofers? I know JL makes a 6.5 sub that is pretty good.
I ended up getting speaker adapters from crutchfield, they claimed for 5.25's but they fit the 6.5 infiniti kappa perfect midbasses fine in the doors. The only problem is they stick out far enough that I could not get the bottom of the door panel to snap back into place, but it is truly not noticable (and I am pretty picky)
notacop u could fix the door panel not snapping back in at the bottom. All you do is pop out the door panel again, and look at the back of the speaker grille on the panel. There will be a ring that is sticking out. Cut this off with a utility knife or scissors and the panel will sit flush.
rvascion
Nov 12, 2020 03:23 AM
Subaru86
Scion FR-S ICE & Interior
Sep 10, 2015 08:11 AM
