2008 Transmission Problems
Old Oct 2, 2009 | 02:51 AM
juzlookzfazt's Avatar
Default 2008 Transmission Problems
Hey all. Tonight my transmission stopped working correctly. My 3rd and 4th gear don't work. Third and fourth go in without clutching in and it feels extremely smooth with absolutely no resistance. I still have to clutch in for 1st, 2nd and 5th but 3rd and 4th goes in without clutching. In-fact, I can put the gear selector into 3rd without the clutch and the car will not move, not even a shudder. As far as fourth gear, I don't have to clutch in either but when when I DO clutch in and then clutch out, 4th gear begins grinding.
I have no transmission or motor modifications as I am mechanically bone stock with only 42,800 +/- miles on the meter. Anyone ever experience this? Should I expect a hassle from Scion? I intend on going in tomorrow and any background info on recalls, tsb's, or general issues that other Scion tC owners are experiencing.
Old Oct 2, 2009 | 04:44 AM
SteveTC_RS_4-0's Avatar
if you went with the standard 33,000 mile warranty, your screwed.
if you paid for the 75,000 mile warranty like i did, your good
Old Oct 2, 2009 | 06:09 AM
UTI_superwhite's Avatar
they might help you out but iam not sure....it sounds like your 3/4 syncro is out to me.
Old Oct 2, 2009 | 12:53 PM
my06tc's Avatar
man every other day im hearing lots of problems with the newer scions..either the tranny broke or clutch went out....i have a 06 tc with 48k no problems yet(knock on wood)but your problem is something the dealer has to look at just becarefull they dont BS you
Old Oct 2, 2009 | 12:59 PM
xroad2oblivionx's Avatar
dude! the same exact thing happened to me, like exactly how you described it. well $400 and my friend hooking me up later, i have an 06 trans in and it's so much better. before that i took my car in the first month of having it to get checked out cause 3rd was acting funny and they told me to bring it back when it broke T_T you can guess the rest.
Old Oct 2, 2009 | 02:50 PM
How much should I expect to pay if it is the clutch?
Old Oct 2, 2009 | 03:03 PM
Jan06xB's Avatar
NOT the clutch . . . shifter fork or gears on that fork . . . if the linkage is moving properly then there is a problem inside the tranny. If you have been banging gears then it was weak and you broke it but if you always shift normally and don't rest your hand on the shifter when driving then it sounds like a defect and if so then they may cover it if enough of them break even if beyond the warrenty.
Old Oct 2, 2009 | 05:56 PM
I just came back from the dealer and as an update, my service advisor says someone who serviced my transmission poured the incorrect fluid in there. She said the fluid has the viscosity similar to used engine oil. Which baffles me because they never touched the transmission as far as I am concerned and neither have I. I cannot at the moment assume or vouch the same for the original dealership I bought my tC from, though. Anyway..they said they are covering it under warranty although I may be out of a tC for a week or so. At-least they are helping out the consumer after the purchase! (wo0t!). I guess I'll give an update as I receive them.
Old Oct 2, 2009 | 06:26 PM
Am I covered for a loaner car? Does anyone know?
Old Oct 3, 2009 | 03:46 AM
DJ08tC's Avatar
Opps miss read,
not sure about the loaner car
Old Oct 3, 2009 | 04:05 AM
draxcaliber's Avatar
you should be covered for a loaner car unless they have a problem with loaning a car to somebody under 25 or whatever, some places do, some don't, mine doesn't.
Old Oct 8, 2009 | 03:11 AM
They loaned me one. An 09 Camry. Man this thing is beat up! People have no consideration for others property for real. 2 ft scuffs on the hood, 2 dents on the passenger side door, the splash shield and fog-light cover is missing on one side, the interior carpets have stains and miscellaneous dents and scratches littered all over the car. The rental only has 1380 miles or so. Incredibly ridiculous. I'm about to clean this car up for these people for real haha.
Sooby
Scion tC 1G Wheel & Tire
11
Apr 8, 2020 11:51 PM
RayScionXB
Regional - Pacific South
19
Mar 5, 2015 08:22 PM
RayScionXB
Regional - Everywhere Else
Mar 3, 2015 08:27 PM
GrumpyCat
Feb 10, 2015 02:52 AM
gularti
Dec 4, 2014 01:21 PM
