one ton grage shims?
Old Feb 4, 2005 | 06:12 AM
peabe's Avatar
Default one ton grage shims?
i probably sound like an idiot but im new to the whole car thing and just wanted to know what these were...
what are one ton garage shims and what do they do?
what exactly does the offset do?
what do rear spacers do?
please be gentle. im new to this. thanks in advance
Old Feb 4, 2005 | 06:25 AM
squirrel's Avatar
www.onetongarage.com
Old Feb 4, 2005 | 07:03 AM
badtouch's Avatar
they are spacers which are made to make higher offset/wider wheels fit without rubbing or having to perform suspension modifications.
if you take a rim and look at it from the top, cut it in half, and measure from where you cut the wheel in half to where the wheels mount up to the hub, this is the offset measurement. it is simply a spacing measurement.
if your talking about rear spacer shims, its a piece of metal you attach behind the rear hub instead of using a spacer between the wheel and hub. this just gives you the option of running a higher offset wheel without having to extend the studs to run a larger spacer. spacers in front/outside, shims in back/inside. 5mm is the max recommended to safely run on stock studs. hope i got it all
Old Feb 4, 2005 | 07:05 AM
JdMBboFSD's Avatar
wow...that some good info...thanks...
Old Feb 4, 2005 | 01:46 PM
peabe's Avatar
double thanks squirrel and badtouch for answering the questions and not making feel like a moron. :D
BlingSlade
Oct 19, 2016 12:39 AM
deademon
Mar 31, 2016 09:25 PM
Lexparker
Oct 23, 2015 11:39 PM
prescottn
Sep 22, 2015 01:30 PM
prescottn
Sep 13, 2015 09:04 PM
