turbos, exhaust, intakes
s/c belt slipping? i have the solution ..
Old Oct 12, 2009 | 04:15 PM
cmcpride's Avatar
Default s/c belt slipping? i have the solution ..
ive been haveing problem ever since i installed a 9.5 -12. or a 14.0 lb pulley, with belt slipping. belts are ether to tight or to loose.at first any new belt work fine but after a while they expand and belt starts to slip. so i ended up makeing a idler pulley that allows you to use your old bearing. could be used with any s/c pulley. once i replaced the old idler pulley with my updated pulley. belt stop slipping even with old belts. no matter what rpm from 1000 to 7000 rpm. i posted pics. cost . well the most expensive part was hard Anodizeing the pulley. ill post prices with and with out Anodizeing pulley later.. thanks .
Old Oct 12, 2009 | 04:17 PM
ack154's Avatar
You'll need to become a forum sponsor if you actually want to sell parts (beyond what would be considered a "one off" classified sale).
If you aren't an actual commercial entity and just want to make a few parts yourself to help the community - contact Tomas about becoming a "Trader" if it is still an option. Otherwise, you'd need to contact Internet Brands about advertising: http://www.internetbrands.com/autonetwork
sciontc008
Scion tC 1G Aero & Exterior
Jan 20, 2016 05:10 PM
olyellr
Sep 28, 2015 10:32 PM
Ksn
Sep 21, 2015 06:21 PM
mcnick0495
Scion tC 2G ICE & Interior
Sep 8, 2015 02:58 PM
bmxScion
Jul 23, 2015 12:07 AM
