problem with steering...help
Old Oct 19, 2009 | 05:00 AM
05FMtC's Avatar
Default problem with steering...help
so lately i have been hearing this creeking noise coming from around the steering wheel when i turn. the faster i turn the wheel, the higher the pitch of the sound. then the other day in the morning (it was probably in the low 60s) i noticed a similar noise from under the pass side dash around the glove box when i turned the wheel.
what can this be? the car drives normally this happens a few times a day and it is getting annoying. i also tried to adjust the height of the steering wheel. i normally drive with it all the way down. so i put it up and it still made the same noise.
i hope its not my suspension that is somehow causing this.
i am dumped on f2 version coils probably a good 3.5-4 inches...
the car is a 05 and is about to hit 60k miles in a few days probably...
another thing. do you guys think that steering is covered under the 5yr/ 60k drivetrain warranty?? i just checked my miles and its 59745...
Old Oct 19, 2009 | 05:08 AM
jnaval's Avatar
It's probably the PS itself, maybe the belt or the PS pump.
Old Oct 19, 2009 | 07:56 AM
1SL0WTC's Avatar
try tightening the top coilovers? mine did that and i always tighten the top with a 17mm box wrench when it creeks.
Old Oct 19, 2009 | 02:23 PM
XIEmperorIX's Avatar
Whether it's covered or not depends entirely on the nature of the problem. Does it only happen when turning or does it happen when you go over bumps to?
Old Oct 19, 2009 | 04:03 PM
05FMtC's Avatar
its only when the wheel is turned. i dont think it has anything to do with the coilovers. it almost seems like the noise is coming from inside the cabin at times...
Old Oct 19, 2009 | 06:33 PM
05FMtC's Avatar
This morning i brought the car to toyot. The service ppl here said that it would not b covered under warranty because it seems to be a wear and tear issue. They said it seems like a busing on the steering column needs to be lubed. They are taking a look at it right now so ill keep u all posted. He did say that its common.
RY_TC07
Jul 18, 2017 05:18 PM
bravosixniner
May 24, 2015 09:56 AM
ScionXa06
May 18, 2015 10:05 PM
claiknx
May 17, 2015 11:44 PM
Moth
Apr 14, 2015 12:17 AM
