Dome light
Old Oct 22, 2009 | 05:42 PM
valkyrie6x6's Avatar
Default Dome light
My dome light quit, It works fine, it will turn on, but does no dim and go out, It stays on all of the time. Is this the timer unit. All other items work.
I'm puzzles
TIA
Old Oct 22, 2009 | 05:46 PM
Jan06xB's Avatar
Is the light switch in forward or rear position? If you wait about 10 minutes does it go out?
Old Oct 23, 2009 | 03:40 PM
If the switch is formard it comes on very bright if the switch is pushed back it is dimmer. but never goes out.
Old Oct 23, 2009 | 03:51 PM
Jan06xB's Avatar
You should check all the door buttons and see if they are all in good condition. Three are all connected together Passenger front and both rear side doors, the driver door is separate and the rear hatch is separate inputs to the control module that works the light and the door locks. You may have a button that is grounding out a little all the time. The Module is located under the dash just to the left of the speedo and is a bit of a pain to get to other than from the top by taking off the instrument cover. There should be posts in SL somewhere of how to do that. It is a very expensive module like $480 I think was the last price I remember. The rear hatch has some sort of tip switch or something connected to the latch . . . not sure about it.
Old Oct 23, 2009 | 07:52 PM
Default dome light
thanks I'll check all that, if not off it goes to the dealer I have an extended warrenty $50 deductable
Old Oct 23, 2009 | 11:17 PM
Jan06xB's Avatar
Oh yeah forgot to mention this but is the little door open light lit on the dash??? And did you change dome light bulbs or add any wiring to it?
Old Oct 24, 2009 | 04:46 PM
No Door lite showing open and did not make any changes to the light pulb or wiring.
Old Oct 24, 2009 | 05:38 PM
Jan06xB's Avatar
Hummmm sounds like a malfunctioning module or a wiring short to ground turning the light on a little. PM sent.
Old Oct 27, 2009 | 08:15 PM
KevinA's Avatar
Would this module be messed up on my car? I was replacing the dome light (was working fine) after installing - nothing. I've tried putting on the old dome light and there is just no power there.
Since this is my fault, I'll be hitting the junk yards for a replacement. Does anyone have a picture or a part number for this module?
Thanks!
wonderworm
Nov 19, 2023 01:44 AM
horsefeathers
Sep 17, 2023 11:12 PM
XB06
May 30, 2015 02:42 AM
lexobx
Scion xD Drivetrain & Power
Dec 7, 2014 05:52 PM
cowboy
Jan 13, 2004 07:55 AM
