turbonetics wastegate
Old Oct 28, 2009 | 04:09 PM
scion_andrew's Avatar
Default turbonetics wastegate
Ok so i finally had a day off an called turbonetics to see how to adjust this waste gate, (horrible customer service) they told me that as long as i have the red sping in there it will hit 9lbs, but then rangerda told me it is adjustable, so then wat do i do i just want it 2 be set on 9lbs! haha
here are the pics
Wat do i do with this to max it out move the bolt to the top or bottom?
also there is a vac port on the botton an one at the top, the top is just empty so i leave it likt that? or wat is the top one for?
Thanx!
Old Oct 28, 2009 | 04:34 PM
rangerryda's Avatar
The top one is for running a boost controller to change your boost setting instead of using the adjustable portion on the top of the WG. You are basically just adjusting the "pre-load" of the spring on the WG. If you are not using an external boost controller (manual/electronic), then you leave the other port open with nothing on it.
My guess would be if you kept the nut and screw assembly off of the WG, you would have to plug the hole and then you could run whatever spring pressure you wanted to based on the spring inside the WG. I'm not sure why but Turbonetics discontinued the non-adjustable WG so I don't know how they wouldn't have an answer for your question.
From what I remember, if you run the screw portion down further, you will make more boost and the more you back it off, the less boost you get. You just have to dial it in until you reach desired boost level.
Old Oct 28, 2009 | 05:41 PM
ok got it figured outfrom ur post an callin turbonetics like 3 times haha
rudeee people over there at turbonetics!
Old Oct 28, 2009 | 06:41 PM
scikotictc232's Avatar
thats weird they were always kool with me. Could be because i was thinking bout spending money with them.
SloTC1
Aug 16, 2018 02:45 PM
bigAL
Mar 19, 2018 06:00 AM
vi3tb0i09
Sep 23, 2015 08:32 PM
brett561tc
Sep 15, 2015 06:33 AM
Feb 1, 2006 06:55 PM
