BYPASS CLOSED LOOP(open loop tuning) questions
Old Oct 30, 2009 | 03:52 AM
cburglb34's Avatar
Default BYPASS CLOSED LOOP(open loop tuning) questions
okay aimed at gurus....i know some of the people here have gotten around our self learning pesty ecu by just unplugging the front o2 sensor thus bringing the ca rinto a constant open loop...
how did you guys like that, and draw back beside the check engine light?
i feel like it would make life soo much easier
Old Oct 30, 2009 | 04:02 AM
Hix's Avatar
Hix
Not really. PM crush02342002 he tuned my car in open loop. It isn't as easy as you would think on our cars. Any little variance causes a large effect overall. Plus when running the A/C over not you will have variances. Unless you want to change your tune every time you run the A/C you will have a good 1-1.5afr difference across the board.
Old Oct 30, 2009 | 04:04 AM
cburglb34's Avatar
dont need ac in maryland we have windows for that and heaters for the res of the year
Old Oct 30, 2009 | 04:12 AM
Hix's Avatar
Hix
Then you probably could do it without a problem. Just cut the o2 wire on your harness so you can reattach if you don't like it. You will throw a P2237 code or something like that. crush02342002 might have a basemap at that tune you could run, just PM him.
Old Oct 30, 2009 | 04:16 AM
cburglb34's Avatar
im tuning on safc so no base tunes for me...and theres better ways at approaching not running a front o2, like unpkuging the connector under the hood..
gingles's Avatar
i run open loop....i like it....although if i had to go back....i would keep it in closed loop. theres no reason to run open loop. people say you cant partial tune, well you can with the greddy ultimate. you make a base fuel map for wot, then use the airflow adjustment map for partial throttle. only reason why i did it was i didnt have 220 to drop on an o2 sensor but i plan on getting it back on. you will never have as good of gas mileage compared to closed loop. plus you loose cruise control...well not loose it, but say im cruising at 15.0 afr....as soon as i turn cruise on it drops to 11.0.
with all that said....just get someone to tune your car with closed loop running. but if you want a tune thats open loop, i have tons. you have to tune alot more running open loop. i use i think 6 maps compared to using like 2-3 running closed loop.
Old Oct 30, 2009 | 04:17 AM
ScionFred's Avatar
Huh? Which Maryland do you live in? LOL
Old Oct 30, 2009 | 04:20 AM
cburglb34's Avatar
LOL you act like we get above 90 around here....and when we get near 90s its only for a couple days this summe ri never used my ac.....it makes too much vibrations and drains power...
for the record, near rockville
Hix's Avatar
Hix
Tape up the connector and don't leave it open under the hood.
Old Oct 30, 2009 | 04:22 AM
cburglb34's Avatar
lol and scionfred you were right about safc not being able to do anything with stock injectors i tried to tune on stock injectors today and lets just say only time under OWT that i wasnt seeing a 15.7 afr was at 4k-4.5k then the safc/ airflow was maxed and fuel just couldnt keep getting pumped..
will have 410cc in tomorrow hopefully itll add enough fuel
gingles's Avatar
mine hasnt been taped up for over a year...its fine.
Old Oct 30, 2009 | 04:42 AM
m6ar2cel6oTC's Avatar
WTF! 220 on a o2! bro i can get you one for 100 bucks ngk brand. thats what i have and have not had a problem since.
Old Oct 30, 2009 | 04:44 AM
cburglb34's Avatar
lol yea i got mine on oxygensensors.com for 160 brand new i think trdsparks sells it for 162
Old Oct 30, 2009 | 04:55 AM
gingles's Avatar
lol....that was from autozone.
Old Oct 30, 2009 | 05:12 AM
ScionFred's Avatar
I hope so too. You're just gonna have to adjust your boost level to match the SAFC and injector limitations. Even 200whp will still be a lot more fun than 150whp. You can always upgrade the injectors and EM later. Then you can get your A/C back for those 95F, 95% humidity days in July and August.
Old Oct 30, 2009 | 05:21 AM
cburglb34's Avatar
yea i have a 4psi spring in the garage if push comes to shove ill throw it in
Old Oct 31, 2009 | 04:46 PM
deathbyc4's Avatar
dang! you shoulda PMed me to remind me lol. alcohol makes me forget things.......
i have my base map some where....
Old Oct 31, 2009 | 05:07 PM
deathbyc4's Avatar
i couldnt find it, ill have to pull it off my safc. may take me a bit.
Old Oct 31, 2009 | 10:40 PM
cburglb34's Avatar
lol wasnt tryna bug you about it, anyways a base tune would be nice right now i have 410cc and afr is at 12.2 and then goes to 11.8 im adding about 34% fuel from 4k to 5500...then goes down to about 28% added till redine
Old Nov 1, 2009 | 01:44 AM
deathbyc4's Avatar
give me the corrections you have for hi and lo throttle and the closest/ most detail you can give me of the AFR between 4 and redline. ive been busy all day with modifying xbox's lol
my06tc
Jun 25, 2015 12:18 AM
tha17
Feb 5, 2015 12:56 PM
TotalChaos
13
Feb 4, 2015 10:24 PM
armyrockmorales
Dec 28, 2014 10:39 PM
umnitza
Dec 1, 2014 06:26 PM
