need some help with thermostat
Old Nov 4, 2009 | 02:28 AM
przemko's Avatar
Default need some help with thermostat
Hi guys
Need some advice what to do to change the thermostat.
I'm wondering if there is any plug so i can get rid off coolant?
Got some problems with warming up the engine so i start with the thermostat first. Any advices
Thanks in advance
Old Nov 4, 2009 | 12:28 PM
weezyfbayba's Avatar
there is a thing on the bottum on the rad to drain the coolant. get the TRD thermo. it makes the car stay colder
Old Nov 4, 2009 | 05:49 PM
syberspyder's Avatar
http://www.trdsparks.com/install/PTR01-21050-90inst.pdf
Old Nov 4, 2009 | 08:20 PM
przemko's Avatar
thanks guys that's what i've been looking for.
I search also about how much coolant will go into Tc but didn't find the answer.
Also is there any special way to fill up the system?
Old Nov 5, 2009 | 03:09 AM
rangerryda's Avatar
There are little white wingnut looking things at the top of the radiator, once you fill the system (including overflow tank), let the car run for just a sec and open one of those until the air stops and fill her up. Keep an eye on the overflow tank for the next day or two to make sure you're not running low.
In regards to how much coolant, "Cooling system capacity - manual transmission 6.8L(7.2qt) - auto 6.7L(7.1qt)"
Above was found on https://www.scionlife.com/forums/scion-tc-1g-owners-lounge-1605/must-read-tc-owners-manual-cliff-notes-12963/ . Nifty little sticky.
Old Nov 6, 2009 | 01:15 AM
przemko's Avatar
just finished works fine thanks guys...
soros151
39
Apr 21, 2016 09:24 PM
electrongeek
Jul 1, 2015 04:02 PM
BManAmericae
Jan 18, 2015 12:17 PM
madmarx
16
Oct 18, 2012 02:46 AM
jdanefellows
Mar 21, 2010 05:22 AM
