do you need to stick your head under car to install axleback/exhaust?
Old Nov 10, 2009 | 01:34 AM
tom7723's Avatar
Default do you need to stick your head under car to install axleback/exhaust?
lol...so basically I want to install an after market exhaust. I haven't bought it yet and am still deciding on what to get. But in the list of things I want to get done, I need to figure out what I can install myself and budget my priorities.
My question is: for all those that installed the axleback yourself, did you jack up your car and stick your head under your car to remove stock exhaust and replace with aftermarket exhaust?
I read a few posts saying that some of the nuts are super tight and may require an air gun....or huge bicept. Haha i don't want to try loosening nuts with the entire car dangling over my head. I personally don't trust jack stands...
Old Nov 10, 2009 | 01:36 AM
DJ08tC's Avatar
Uhm your pretty much have to get under there to reach the bolts on the midpipe unless you have super long arms, and you are going to have to take off the rubber hangers which are a pain.
Old Nov 10, 2009 | 01:39 AM
eatthecrayon's Avatar
Originally Posted by DJ08tC
super long arms
lol thats what i used bro. But seriously those hangers are a pain.
Old Nov 10, 2009 | 01:45 AM
DJ08tC's Avatar
well i just jacked it up and laid under there, made it a lot easier
Old Nov 10, 2009 | 01:49 AM
Yeah i used jack stands.. laid a towel on the ground and used the F alot. Most come with DIY easy instructions.
Old Nov 10, 2009 | 01:52 AM
tom7723's Avatar
does anyone get hurt from doing this...that scares me ____less lol
edit: scares me a lot
Old Nov 10, 2009 | 01:54 AM
DJ08tC's Avatar
If you use 2 jackstands on each side in the right spot there ill be no problems whatsoever, I have used them a lot. Just make sure you are on flat ground and put something in front of the wheels so it wont roll.
Old Nov 10, 2009 | 01:56 AM
Domo's Avatar
Yes you need to get under your ride to install an aftermarket exhaust and yes its simple. You don't need to be strong to get things done, you just have to use your common sense. Just like the question you asked..if you really thought about it before creating this thread, you would have gotten your answer already.
I thought about it when i was under my car but i was determined.. Have a buddy with you lol idk dude you will be fine
Old Nov 10, 2009 | 02:17 AM
Jan06xB's Avatar
Drive it over a hole in the ground if you are worried about things falling on you. The next best thing are a couple of ramps but I think you will have more luch with the pipe over the rear suspension if the wheels are hanging down from the body.
Old Nov 10, 2009 | 03:02 AM
bigBOAT's Avatar
where at in chicago are you bro the axle back is easy just jack up the back and take the hangers off and the 2 bolts on the mid pipe
Old Nov 10, 2009 | 03:22 AM
highvoltage1's Avatar
you dont have to if your this guy!
Old Nov 10, 2009 | 03:29 AM
smilezdc's Avatar
spray some WD40 on the rubber hangers.. it'll be a little easier to get off..
Old Nov 10, 2009 | 04:24 AM
SteveTC_RS_4-0's Avatar
just hit up dhalsim from street fighter 2.
Old Nov 10, 2009 | 04:33 AM
thendawg's Avatar
Haha cant believe im reading this post - i was under my car with no front end in it when i had the motor out - the only thing keeping the front end off the ground was two jackstands - dont know why you dont trust them - as long as youre on level ground and the jack stands are rated for the load (i use 2 1/2 ton stands - our whole car only weighs 1.5 tons) you are perfectly fine - one thing i would NEVER advise is to get under a car supported by a jack alone - always a very bad idea - but as long as you have jack stands youre good to go.
Old Nov 10, 2009 | 04:35 AM
thendawg's Avatar
Also just fyi - as long as the car is on level ground and on properly rated jack stands - you are putting your life in more danger by simply driving your car than you are being under it
Old Nov 10, 2009 | 06:17 AM
athletefeet66's Avatar
jacks stands ftw. its like a 20 min install.
Old Nov 10, 2009 | 03:47 PM
tom7723's Avatar
thanks everyone for their "support"...hahahaa jk
but anyway...i think i have a lot more faith in jack stands now lol
Old Nov 10, 2009 | 03:53 PM
tom7723's Avatar
one more quickie...what's better/safer: 2 jackstands or 4 jackstands?
Old Nov 10, 2009 | 04:38 PM
2 jackstands since the wheels are on the ground but either set up correctly are safe. you only need two, if that, for an exhaust. once you have been under your car a couple of times you will get alot more comfortable with it.
