little help installing boost gauge
Old Nov 12, 2009 | 01:08 AM
tc1003's Avatar
Default little help installing boost gauge
Can someone please tell me the best place to tap the vac line for a boost gauge install. a picture would be great
Old Nov 12, 2009 | 01:18 AM
Hix's Avatar
Hix
Brake booster. It is the metal line attached to the firewall. Both sides have rubber hose that you can tap in without much effort.
Old Nov 12, 2009 | 01:28 AM
tc1003's Avatar
that line is a bit to big for the t I have. Anything else, I thought I was shooting for close to the intake (from what I was told) I just dont know what line to use.
Old Nov 12, 2009 | 01:30 AM
tc1003's Avatar
This is the first time I am running this type of line so please understand I don’t know that much about selecting the line. Electronics im fine motor stuff im green
Old Nov 12, 2009 | 01:33 AM
Hix's Avatar
Hix
That is the only stable vacuum source on the car. The lines off the throttle body fluctuate alot.
Old Nov 12, 2009 | 01:38 AM
tc1003's Avatar
Just want to make sure I have the correct line, it is a steel line in the center of the firewall? It is bent out off the firewall on both ends.
Old Nov 12, 2009 | 01:39 AM
weezyfbayba's Avatar
go to www.ptuning.com and buy there vac block then use the brake boosted to hook it up and then run the boost gauge vac line to one of its fittings bingo all done!
Old Nov 12, 2009 | 01:40 AM
Hix's Avatar
Hix
Yep. Orileys has staggered T fittings too.
Old Nov 12, 2009 | 01:41 AM
my old turbo kit but ull get the picture look top right ull see the turbofailoytas vac block
Old Nov 12, 2009 | 01:45 AM
Hix's Avatar
Hix
http://www.dezod.com/pd-dezod-motors...m-manifold.cfm
Old Nov 12, 2009 | 02:02 AM
crush02342002's Avatar
you got it
Old Nov 12, 2009 | 03:43 AM
gingles's Avatar
lol...it looks like theres hotdogs by your windshield wiper but i looked closer to see wire stripers
Old Nov 12, 2009 | 03:54 AM
scion_andrew's Avatar
So u just take that metal part out an put the vac block in its place?
Old Nov 12, 2009 | 04:06 AM
lol...thats when you get hungry during install
Old Nov 12, 2009 | 04:08 AM
winna winna chicken dinna....you will however need just a short piece of vac line to extend the end to vac block and a vac coupler. dont forget small wormdrive clamps.
Old Nov 12, 2009 | 04:09 AM
I just noticed justin you polished your VC....looks good brethren
Old Nov 12, 2009 | 04:12 AM
its alll faded im doing if wrinkle red when im not lazy.. prolyl when i install my sc 60 turbo!
Old Nov 12, 2009 | 04:13 AM
yeah they tend to do that if not coated, takes a bit more effort but i like mine polished. just got to get under the hood to polish it up every now and then.
Old Nov 12, 2009 | 05:25 AM
gingles's Avatar
what did you guys use to polish it?
Old Nov 12, 2009 | 06:21 AM
depending on the casting i started with 600 grit sandpaper (steel wool works well too if the casting was good). 600 to 1000 to 1500 to 2000 then to mothers power cone w/ aluminum polish (turtle wax brand polishing compound works well too)
my06tc
Jun 25, 2015 12:18 AM
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
mattjk
121
Dec 22, 2004 10:49 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
