clutch install
Old Nov 14, 2009 | 10:22 PM
skinnayyy's Avatar
Team Scionara
Default clutch install
so i'm having the hardest time ever getting the axels pulled out. could anyone point me to a diy other then the one by tennythetc on here and the one on yoursciontc to change a flywheel. or any sort of tips and pointers.
pictures would be the best
Old Nov 14, 2009 | 10:27 PM
aen's Avatar
aen
the driver side one huh.
grab a crowbar and jam that thing in there and use your legs.
you likely won't snap the axel so dont worry.
Old Nov 14, 2009 | 10:29 PM
skinnayyy's Avatar
Team Scionara
i can't get both of em out. we have been using a pry bar on the driver side and then when we took the bolts off the bearing on the pass. side it doesn't seem like those even do anything
Old Nov 14, 2009 | 10:32 PM
aen's Avatar
aen
weird. the pass one was easy as hell
i just undid the bolts and pulled slightly and it came out.
the drivers side one takes a bit of finesse because you thin you'll break something. you won't.
also, NEVER pull on the axel itself. that's bad.
Old Nov 14, 2009 | 10:45 PM
skinnayyy's Avatar
Team Scionara
i wish it was coming out easy nothing is working at all.
Old Nov 15, 2009 | 12:18 AM
all4degame's Avatar
You can go rent out an axle puller from your local auto part shop, or get a big freaking pry bar. We used those in conjunction to get axles out of my friends tc
Old Nov 15, 2009 | 01:58 AM
skinnayyy's Avatar
Team Scionara
alright i'll see if i can get one tomorrow when we get back at it
i didn't think there was an actual tool called an axle puller haha
the stuff they make for cars.. ha
Old Nov 15, 2009 | 02:09 AM
aen's Avatar
aen
yep, it looks like a claw and goes around then you just use an impact hammer to get it out.
dude just get a long crow bar that's made of tempered steel and go at it.
Old Nov 15, 2009 | 02:27 AM
skinnayyy's Avatar
Team Scionara
yeah... we did that for an hour... no go there.
Old Nov 15, 2009 | 02:40 AM
aen's Avatar
aen
took me two days my first time.
it's in there really tight.
Old Nov 15, 2009 | 03:24 AM
gompka's Avatar
when we did my brothers clutch recently, we found that the dealership had banged in the axle too far when they replaced his tranny. The c-clip got jammed and the bearing got toasted sending crap into the tranny and basically toasting everything else. We had to cut off the axle to get it out. Thats a worst case scenario....
Old Nov 15, 2009 | 03:32 AM
skinnayyy's Avatar
Team Scionara
i'll cry if that's the case haha
i dunno what it is but there hasn't been a sinlge bolt or anything that has come off as easy as it should have... its a 2005 but i don't think 4 years should lock in any thing like that
Old Nov 15, 2009 | 05:25 AM
crush02342002's Avatar
as for the passenger side axle i found the 05-06 since they are older tend to rust-fuse the axle and "carriage" bracket together. you want to take out the two bolts (top side is a pain since you cant hardly see it, i suggest an open ended wrench and elbow grease) then take a sharp instrument to wedge inbetween them and pry them apart. a little persuasion may be in order in the form of a rubber mallet.
the driver side you will notice the notches on it, thats were you want to place your pry bar. try in one notch and rotate the axle to the next notch and pry there....repeat the process till you pop that sob out. that so far has been the easiest for me, however it may not seem like it....lol
btw make sure you have already taken that monster 32mm 12point axle nut off and lowered the whole wheel assembly.
good luck
Old Nov 15, 2009 | 05:41 AM
skinnayyy's Avatar
Team Scionara
i've tried 8 stores and a couple shops around me... and no one has a socket to get the nut off... so we're doing it with the whole hub on and just dropping everthing that it connects to so it is still free of motion. but i'll try the spinning it and prying it apart tomorrow. thanks for tips! i want to get this clutch on!!!
Old Nov 15, 2009 | 05:50 AM
i found mine at advanced auto parts...you want a 32mm 12point deep well
Old Nov 15, 2009 | 03:40 PM
skinnayyy's Avatar
Team Scionara
yeah they didn't have it lol. they had a 32 mm deep well... 6 point haha or a 32 mm 12 point regular... but we're getting by without it... ish lol
Old Nov 15, 2009 | 04:41 PM
skinnayyy's Avatar
Team Scionara
and to top it off... when we are trying to separate the bearing... it looks like it's welded together... did any of you have that problem? we're hitting it with a heat torch then going back at it now
Old Nov 15, 2009 | 05:16 PM
I wouldn't do that...your gonna cook the grease out of it...
Old Nov 15, 2009 | 05:23 PM
all4degame's Avatar
eek. definitely don't hit it with a heat torch. That's a bad idea. I really think you need to get that 32mm nut off first before you precede in doing anything else. You may end up binding the axle jimmying around with it.
Old Nov 15, 2009 | 05:26 PM
coryjames's Avatar
i didnt ever pull off the axle nut to do my clutch the axle is a bear to get out just got to mans game it grow a pair get it done tell it who the boss is make it say your name you know treat it like a lady
