boosted + hard driving = Thrashed Tranny lolz
Old Nov 25, 2009 | 03:07 AM
greenbean24's Avatar
Default boosted + hard driving = Thrashed Tranny lolz
so im running 2007 tc with 35,000 miles, a 5 speed, and a dezod s1 kit on 8.7lbs, blah blah and i was at the track the other day just driving the ____ outta the scion and as i slow down on the top end i hear a clanking noise, almost like a Folgers can with a bunch of bolts in it. i pulled over to my homeboys and try to diagnose to the problem only to conclude it was somewhere between the input shaft and the axles, greatanyways i drove it back to the house, meanwhile it wouldn't stay in 3rd gear and it sounded like i was supercharged not turbo'ed, ouch. put it on the lift only to find the differential pin that holds the spider gears together had wallered out the hole, broke the little bolt that kept it in place, and managed to machine out about 5 holes in the tranny case. fml long story short i salvaged a junkyard tranny with low miles and im back on the road. the question after all that is are a lot of you guys experiencing tranny failure? ive done the obligitory burnout once and a while at the local car meets and such, but i wasnt expecting failure this early! also are there any companies that sell upgraded tranny parts? ring and pinions, input shafts, gears etc...
thanks!
Old Nov 25, 2009 | 06:02 AM
dang, no one with any tranny building knowledge??
Old Nov 26, 2009 | 03:33 AM
gompka's Avatar
No upgraded parts available, but you can get the stock parts cryo treated and use synthetic oil.
Old Nov 26, 2009 | 03:36 AM
Hix's Avatar
Hix
Transmissions are so cheap used from the junkyard I think every just buys a new one when they blow em up. For the cost of clutch packs for mine I could buy 3 slightly used trannys.
Old Nov 26, 2009 | 03:42 AM
gompka's Avatar
Ditto i'm on tranny #3, but 2nd one that died was put in by the dealership and they failed and thats the main reason it died, they jammed the drive shaft bearing somehow, they must have taken a hammer to it when they put it in.
Old Nov 26, 2009 | 03:50 AM
rangerryda's Avatar
3rd gear seems to be the culprit in almost all of the tranny failures. I think it's partially mis-shifting since its the most exciting and far away shift throw when you are boosted. I don't beat up my tranny but I'm boosted so I guess it depends on how you drive it more than how much power is being made.
Old Nov 26, 2009 | 03:52 AM
crush02342002's Avatar
i never had that kinda issue with the tranny except for the fact the clutch slipped all the time. maybe cause i was on the stock clutch it kept pressure off the tranny gears and various parts. mine is an 07, was boosted on 11psi with a TT simple kit for roughly a year. went to the track as often as i could and even ran drag radials for a short period.
Old Nov 26, 2009 | 04:54 AM
gompka's Avatar
I think it depends on a lot, for me it was 2nd gear that went out, but i learned to drive stick on it. The tranny is picky it feels much better if you ____ slower, not much difference in overall speed but saves the tranny. All in all i'm never letting the dealership touch my car again, that should fix things.
Old Nov 26, 2009 | 03:46 PM
rangerryda's Avatar
hehe ^^ shift got edited because you forgot the "F"
Old Nov 26, 2009 | 03:50 PM
cburglb34's Avatar
well if u take a look at our gears its 4th gear thats the weakest link in our trans due to the way the teeth sit(thanks ptuning for this info) and for that reason they shimmed their 4th gear and are spraying oil all over 4th gear with multiple nozzles
if u have broken any other gears i feel it is just either a driving habit or your trans was just that small percentile of parts that dont quite perform to their standards
Old Nov 26, 2009 | 04:31 PM
Soulquarian's Avatar
Where are you guys finding used tranny's for cheap? I want to get one cryo treated and drop my LSD and Twin Plate in there...
Old Nov 26, 2009 | 05:10 PM
thanks dudes, so im guessing ptuning is running a stock(ish) tranny? and what about those guys with 400-500whp, what kinda tranny setup are they running?
Old Nov 26, 2009 | 05:17 PM
cburglb34's Avatar
everyone is using stock trans excpet for chris rado
Old Nov 26, 2009 | 05:20 PM
SoFloTC's Avatar
stock..
Old Nov 26, 2009 | 05:24 PM
weezyfbayba's Avatar
ive been boosted since mid july and been at 12 psi for about 2 month's. no prob's redline ftw?
Old Nov 26, 2009 | 05:29 PM
agreed....many factors
Old Nov 26, 2009 | 07:47 PM
Blue_TC_Man's Avatar
Hmm i've givin my tranny hell, over 60 runs down the track N/A and on a 70 shot of nitrous with no problems, good fluid and a sure shift seems to do little harm. Cause mine should be gone as hard as I shift but its crisp as when I got it 40k miles ago. Mines an 06 though
my06tc
Jun 25, 2015 12:18 AM
stayintrucha
Scion tC 2G ICE & Interior
Dec 18, 2014 04:36 PM
gularti
Dec 4, 2014 01:21 PM
Risen_Son_Racing
May 6, 2005 02:31 PM
TheRedBox
Oct 8, 2003 04:25 PM
