Jack Stands
Old Dec 9, 2009 | 10:10 PM
xbBrian's Avatar
Default Jack Stands
Sometime next week I will be installing Tanabe NF210 springs. I have a question, probably a dumb one, but where is a good place to support the car with jack stands?
Old Dec 10, 2009 | 12:30 AM
jnaval's Avatar
Use the points marked by arrows on the rocker panel which are designated in the manual.
Old Dec 10, 2009 | 12:31 AM
xbBrian's Avatar
Ill have to check the manual again. All I found before was the front and rear points that are designated to be used with a floor jack.
Old Dec 10, 2009 | 12:52 AM
jnaval's Avatar
The points for use with the spare tire jack and jack stands are on P. 205 and the floor jack points are on P. 236.
Old Dec 10, 2009 | 04:06 AM
xbBrian's Avatar
Thanks.
Old Dec 16, 2009 | 04:50 AM
xbBrian's Avatar
Using jack stands in those locations appears to have bent the metal, is there a safer place to use the jack stands at?
Old Dec 17, 2009 | 03:17 AM
TheCCBox's Avatar
Yea put them on the frame that's what I do is is safe.
For the front you can see place in the front that looks like the back put them there.
__________________
Old Dec 17, 2009 | 03:37 AM
Tyrannosaurus RexB's Avatar
I am so lucky to have 2 hydraulic Hoists at my beck and call whenever I please! LOL!
Old Dec 18, 2009 | 03:43 PM
slowdalpangee's Avatar
Originally Posted by TheCCBox
Yea put them on the frame thats what i do is is safe. For the front you can see place in the front that looks like the back put them there.
That's a nice place to put it. I'm curious, after use, are there little dimples where the stand heads were touching the frame? I was thinking of using hockey pucks with little notches cut out so that the stand head is holding it firmly, and the puck is secure.
Also, when you're raising the car up, where are you placing the actual jack? In my old GTI, the lift points were crushed when not using the scissor jack. I'm afraid to mess these ones up as well.
Old Dec 19, 2009 | 04:07 AM
TheCCBox's Avatar
No I didn't see any damage or marks when i took the jack stands out. It is a good strong frame LOL!! You are going to mess those points up where you put the jack cause they are mad thin and dont know why they fold but you wont tare up the frame.
Old Dec 22, 2009 | 08:25 AM
Other than gravity, what's keeping the stands from sliding? The current set up seems a little slippery with metal on metal contact. Maybe even a rubber coaster would help.
Old Dec 22, 2009 | 02:41 PM
jnaval's Avatar
If lifting the rear, setting the transmission into gear or park with wheel chocks. If lifting the front, setting the hand brake with wheel chocks. As for jack stand points, people put cloth, rubber, foam, carved out pieces of wood, and carved out hockey pucks. The wood and the hockey puck works well on the outer jack stand points, just carve a little groove for that metal flap and that will prevent it from bending, for the most part.
TTCCC
Feb 25, 2011 11:30 PM
XBinRochester
Mar 15, 2010 10:22 PM
GQQSE13
Scion tC 1G Wheel & Tire
9
Jan 8, 2009 01:12 AM
Guamzson
Regional - Pacific Northwest
Dec 27, 2007 09:02 PM
pjracer
Nov 21, 2005 02:10 AM
