Brake light on dashboard
Old Dec 14, 2009 | 01:46 PM
JessXA's Avatar
Default Brake light on dashboard
The brake light on my dashboard started popping on two days ago. It doesn't seem to happen at any specific time, just random and for only a few seconds.
The parking brake is down and there's nothing stuck in there causing it to pull up.
Is this a warning to check brake fluid?
Old Dec 14, 2009 | 03:09 PM
1slowtc's Avatar
Strictly Scionized
i would venture to say yes that would be the frist thing i would ck if there was a problem with the braking system there should be more lights if the brake fluild is ok look to make shore that the sensor on the e-brake handle isnt falling off
Old Dec 14, 2009 | 03:27 PM
joshuabowman's Avatar
My 07 tc is having a simulare problem, however it only comes on when i take off from a red light fast. As soon as let off the gas the light goes out. brake fluid is good so i'm still trying to figure this one out.
Old Dec 14, 2009 | 04:07 PM
1slowtc's Avatar
Strictly Scionized
ck the sensor on the brake cable it sounds like when u take off it has just enough play to kick the light on it might be loose
Old Dec 14, 2009 | 04:31 PM
jct's Avatar
jct
its just telling you to replace your brake pads
Old Dec 14, 2009 | 05:53 PM
faux_ghost's Avatar
check your brake fluid level....simple fix
Old Dec 14, 2009 | 06:04 PM
SquallLHeart's Avatar
... check your brake pads first.
low fluid level is caused by worn pads. if you blindly fill your brake fluid... you'll have a fun time when you replace your pads..
and/or have an even more exciting time when you replace your rotors too because of your ignorance to check the real cause of the problem.
only add fluid after you check your pads to make sure they are ok. never should you ever need to do add any brake fluid on a normal basis.
Old Dec 14, 2009 | 06:43 PM
burstaneurysm's Avatar
Yep, time to replace your brake pads. The indicator is lit because your brake fluid level is low... The fluid level will naturally get lower as your pads wear out because there's more fluid in the system as the piston extends.
Get the pads changed, you shouldn't need to add any fluid.
Old Dec 14, 2009 | 07:47 PM
jct's Avatar
jct
when i changed my brake pads a few weeks ago the pistons in my calipers were pushed so far out it was almost scarry... but i did not need to add fluid what so ever
Old Dec 14, 2009 | 07:56 PM
1slowtc's Avatar
Strictly Scionized
so u all are telling me that u just jam the piston back into the caliber lol whatever u arent supose to push that fluild backwards u are to break the bleeder lose and push the piston back then refill with fresh fluild this also helps it from braking down over time because in a nut shell u are putting fresh in and getting rid of the old that is sitting in the caliber but to all there own...
Old Dec 14, 2009 | 08:01 PM
jct's Avatar
jct
take a big c-clamp and push the piston back into the caliper no need to open up the bleed valve it is a closed system after all... push it in slowly with the c-clamp... and you'll be fine
Old Dec 14, 2009 | 08:23 PM
XIEmperorIX's Avatar
the only reason to open the bleeder valve is if you want to bleed the brakes to get any possible air out or to flush the system. If this is the OP's 1st or 2nd set of brake pads (Depending on driving habits) his fluid should be fine.
Old Dec 14, 2009 | 08:26 PM
1slowtc's Avatar
Strictly Scionized
Originally Posted by jct
take a big c-clamp and push the piston back into the caliper no need to open up the bleed valve it is a closed system after all... push it in slowly with the c-clamp... and you'll be fin be
i no that but what i am saying is brake fluild brakes down with heat so if u loosen the bleeder and push the old out u put new in kills 2 birds with 1 stone u never have to really worry about the fluild braking down
Old Dec 14, 2009 | 10:22 PM
^^ still unnecessary..
you're still going to need to push the pistons back in regardless.. even if you want to bleed it... and as mentioned.. it's a closed system.. unless you have the tools and preparation to do it.. you're just risking air being introduced into the system.. which is the opposite of the purpose of bleeding in the first place.
but really.. don't think there's enough miles to warrant replacing brake fluid.
Old Dec 14, 2009 | 10:28 PM
kyledye25's Avatar
Your brake pads are wearing. The more worn they get the lower your brake fluid gets because its using more. So basically your brake fluid is low because your pads are worn. You can still drive around on the pads. For a little longer. But add a bit of brake fluid to it and it should go away. Or let it go for some time and replace your pads. The dealership will will want you to resurface the rotors 2. Up to you on that one.
Old Dec 14, 2009 | 10:35 PM
whatever brake fluid you add.. you'll need to take out when you replace your pads..
i wouldn't worry about adding brake fluid.
Old Dec 15, 2009 | 12:54 AM
Just replace the pads. Don't add fluid, don't bleed the brakes. Just replace em.
bostondaniel
Scion xD Suspension & Handling
15
Sep 12, 2020 03:16 PM
xBSciontist
Jun 18, 2019 03:06 PM
YooItsJay
Dec 2, 2015 08:13 AM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
bruceb25
Nov 23, 2014 04:52 AM
