Powerdoor lock problem ...
Old Dec 20, 2009 | 06:18 PM
ToasterOnWheels's Avatar
Default Powerdoor lock problem ...
Hello everyone.. I've been trying to search but can't seem to find what I'm looking for. My xb still has the factory remote to lock and unlock the doors. Last night I pressed the remote to lock and it didn't lock the driverside then today it didn't lock any of the doors nor did the lights flash when I pressed the button. Would anyone know how to fix that or what it could be/experience that before?
Old Dec 20, 2009 | 06:21 PM
One more thing .. It's just with the remote that it won't lock except the drivers side that won't go up or down at all.
Old Dec 20, 2009 | 07:38 PM
MadMike550's Avatar
try a new battery in your remote
does the drivers side work with the switch in the door panel?
Old Dec 20, 2009 | 07:49 PM
thats what i thought also about the remote... that might have to be changed too.. but would that cause the lights (back and headlights) not to blink when i press it?
also, no when i switch the lock and unlock inside the car.. the driverside does not move.. the other door lock switches do not the driverside.
Old Dec 20, 2009 | 07:50 PM
Cereal's Avatar
that happened to me too. try to take the door lock actuator and see if you can spray it with one of those electrical cleaner.. if you can take your actuator apart with ease and just see if you can brush off the dirt..
oh yeah check your remote battery too..
Old Dec 20, 2009 | 08:00 PM
ok.. cool i will tell the man to take a look at it ... thank you hopefully that works. might sound like a stupid question.. but to find the door lock actuator... would it be in the manual? i will look it up online to be sure... thanks again guys and ill post up once we take a look at it and change the battery on the remote...
Old Dec 20, 2009 | 08:14 PM
matt's Avatar
mine doesnt work when its cold out. I leave the car outside, and in the morning, it has issues. during the day, its fine.
Old Dec 21, 2009 | 05:58 AM
Zman's Avatar
My rear driver side door has never unlocked right. Is the actuator hard to get to?
Old Dec 21, 2009 | 12:56 PM
MadMike550's Avatar
it's/they are behind the door panel
Old Dec 22, 2009 | 04:32 AM
well couldnt take the door panel off today.. it was raining here.. but i did change the battery on the remote.. the lights now blink.. but when i press lock and unlock nothing happens.. which leads me to think i need to replace the remote.. when i manually lock and unlock from inside the car.. they work (except the driver side) ...so now another question is... has anyone ever replaced their factory remote?? im going to call the dealership tomorrow but just wanted to see if anyone has replaced theirs or know how much it would cost to replace???
Old Dec 22, 2009 | 08:58 AM
Cereal's Avatar
i think when you replace the battery on your remote you have to reprogram it again to the receiver. but im not sure if the dealer can only do that or maybe someone has a DIY for it.. just search it..
Old Dec 22, 2009 | 01:14 PM
MadMike550's Avatar
https://www.scionlife.com/forums/sho...program+remote
Old Dec 27, 2009 | 09:01 PM
ilovemybox's Avatar
mine does this from time to time i hit unlock then give it a swift hit down and you will here (ping) then it will work
Old Dec 29, 2009 | 06:51 AM
ok well i changed the battery in the remote.. Reprogrammed it using the tutorial given above. ( thank u!) it was super easy to do it... However the driverside doorlock still does not work. It works if I pull it up or push it down or open the door with the key. I tried explaing to the husband where the Actucator was and what was said to clean it but he wouldn't let me see and I doubt he knows what or where it was. He unplugged the white wires that were connected to what hesays is the problem.. The whole actual part that has the buttons u press from inside the car. I tried looking up what the actucator looks like and from what I saw online it looks like a gun shape or something? I don't know bit it was not the part he was telling me needs to be replaced. I love my hubby but he is not car savy in the electronic department let alone scion. Good thing we have a friend who works at Toyota so I'm going to have Him look at it.
Can anyone atleast show me a pic or link to the part that would need to be replaced? (the altucator however u spell it ) so I can make sure I was looking for the right thing?
Old Dec 29, 2009 | 01:45 PM
MadMike550's Avatar
the actuater is in the door it's self..the switch your husband disconnected can easily be tested with a volt meter..test it to see if it is bad or not...
GoodVibes
Scion xB 2nd-Gen Wheel & Tire
Mar 3, 2015 09:47 PM
Kiwibox
Dec 15, 2014 09:46 PM
pier0723
Scion tC 1G ICE & Interior
Dec 3, 2014 03:38 PM
dulcimoo
Jan 4, 2004 03:40 PM
