Spacers
Old Dec 26, 2009 | 12:36 AM
scion_andrew's Avatar
Default Spacers
What is the biggest size spacer i can use while still using the stock studs?
my rims are +45 an i hate it!
Thank u!
Old Dec 26, 2009 | 12:40 AM
The01Cav's Avatar
I am running 5mm spacers for the rear on mine right now, I wouldn't go anymore than that.
Old Dec 26, 2009 | 12:49 AM
can u post a pic please?
an wat were ur rims original + size?
Old Dec 26, 2009 | 12:52 AM
jaewrek's Avatar
I'd say 8mm is the largest you should go on oem studs. Any bigger and you need extended studs or the bolt on spacers. Just make sure to torque em down nicely and check it periodically.
I run 8mm in the back, as well as some of my friends with 240s who have been doing it for quite a while with no problems.
Old Dec 26, 2009 | 12:58 AM
The01Cav's Avatar
My wheels are 18x8 +46mm offset, now +41mm offset.
Sorry no pics right now.
Old Dec 26, 2009 | 01:35 AM
dqlostsoulz's Avatar
I agree with jaewrek. 5-8mm you will be fine. I ran 5mm for the longest with no problems and I went up to 8mm all around.
Old Dec 26, 2009 | 02:07 AM
Hey scion_andrew, you should get some bolt on spacer since your wheels are really sunk in. And you wont need to remove and studs.
Old Dec 26, 2009 | 02:12 AM
XIEmperorIX's Avatar
IMO I woudln't even consider using spacers without extended studs but that's just my .02..
Old Dec 26, 2009 | 04:04 AM
BlkTC's Avatar
im using a 15mm bolt on for the rears with chopped studs.. gonna run a 10mm slip on for the front..
Old Dec 26, 2009 | 05:05 AM
^ so you ended up chopping the studs. I told you..you can du ettt....lol
Old Dec 26, 2009 | 10:18 AM
BlkTC's Avatar
hahahaha yeah.. i had faith in myself.. lmao.. i didn't end up doing it though. i asked my friend, the "dremel master", to do it. HAHA
Old Dec 26, 2009 | 04:25 PM
Bolt on? Any links to where I can get them
Old Dec 26, 2009 | 06:04 PM
riboflavin's Avatar
5~8mm will be maximum (I'd stick with 5mm) but these sizes won't have extended hub bore while covering most/all of your stock hub so your wheel won't sit on the hub bore (studs will have to hold the rim). which is same as running aftermarket rims with bigger hub size without hub centric rings. It should be fine for DD but kinda dangerous if you track your car. I don't recommend it personally.
If you want bigger spacers, just get well-known brand one such as Ichiba, H&R, Project kics, etc that comes with new studs. I'm running Ichiba and they are okay (their studs are kinda weak tho). Ver.1 comes with new studs that you have to replace your stock studs and Ver.2 has studs that's already mounted on the spacers.
What I've learned from my mechanic friend is that if you can turn your lug nut at least 5 full turn then it should be fine for regular use but maybe not for spirited driving/racing.
Old Dec 26, 2009 | 06:05 PM
riboflavin's Avatar
http://www.evasivemotorsports.com/me...e=Wheel-Spacer
Old Dec 26, 2009 | 07:02 PM
http://shop.ebay.com/i.html?_nkw=sci...ters&_osacat=0
Old Dec 26, 2009 | 07:03 PM
Thank u I decided to go with ver 2. 25 mm spaces. Hopefully that won't look sunk in
Old Dec 26, 2009 | 07:23 PM
riboflavin's Avatar
what's width of your rims?
Old Dec 26, 2009 | 07:37 PM
Old Dec 26, 2009 | 07:41 PM
BlkTC's Avatar
http://www.optionimports.com/
Old Dec 26, 2009 | 07:49 PM
riboflavin's Avatar
Originally Posted by scion_andrew
7.5
7.5 +20 should look okay on stock body but it's not aggressive.
