Spacers
Old Dec 27, 2009 | 07:58 AM
BlkTC's Avatar
im at 10+20.. and it's PERFECT!! stretchin 215/40 tire
Old Dec 31, 2009 | 03:47 AM
07-5spd-SprWht-tC's Avatar
im runnin 19x8 +35 on 215/35 all around, on s-techs. is it ok to use larger spacer in rear or use the same size spacers on all 4 corners? tryin to get the flush look but dont know wut size spacers to use
Old Dec 31, 2009 | 04:55 AM
dqlostsoulz's Avatar
^try 10mm spacers
Old Dec 31, 2009 | 03:06 PM
do u think the same setup would be perfect for me? im stretchin 215/35/19 with my 19x8. i know ur a lot lower on those coilovers than me on my s-techs
Old Dec 31, 2009 | 06:40 PM
tCjosh's Avatar
Originally Posted by scion_andrew
What is the biggest size spacer i can use while still using the stock studs?
my rims are +45 an i hate it!
Thank u!
WHAT?!?! is Andrew trying to go flush now?!?!?!?!?!?!?!!!!!!!
Old Jan 1, 2010 | 10:21 AM
BlkTC's Avatar
15mm.. i usedd a 15mm on my 17x8 +35 and it came out nice!!
Old Jan 1, 2010 | 08:35 PM
TJKASS's Avatar
Yeah, a 15 or an 18mm spacer all the way around would get you on your way towards flush and itll go with the stech drop well.
Old Jan 1, 2010 | 08:54 PM
09TRDtc's Avatar
with stock wheels what spacer could i run?
Old Jan 1, 2010 | 08:55 PM
^20mm up front and 25mm in the rear.
Old Jan 1, 2010 | 08:57 PM
09TRDtc's Avatar
with stock lugs and all??????
Old Jan 1, 2010 | 09:10 PM
TJKASS's Avatar
Dear no, for those size spacers youll either need pass through ones that come with new longer studs (tap the old ones out and pull the new ones in), or bolt on ones that bolt onto your stock studs but have new studs mounted in them that you attach your wheel to. Be sure to get ones that are hubcentric though.
Old Jan 1, 2010 | 09:14 PM
Just get the bolt on spacers. Makes it easier.
Old Jan 1, 2010 | 09:28 PM
09TRDtc's Avatar
word an 8mm spacers make a difference in look? or a 5mm spacer? instead of going the longer stud route
Old Jan 1, 2010 | 09:31 PM
Not too much.
Old Jan 1, 2010 | 10:29 PM
TJKASS's Avatar
yeah, i mean 8mm is only about a quarter of an inch, and considering the OEM wheels sit an inch+ into the wheel well it wont be too noticeable of a difference. Dont get scared about bolt on spacers, theyre the best way to go (other than new wheels with more aggressive offsets) and theyre not as difficult to install as they sound.
Old Jan 1, 2010 | 10:31 PM
09TRDtc's Avatar
yea but at 80$ a pair i dont want to spend lol
Old Jan 1, 2010 | 10:55 PM
Well than dont du ett than.
Old Jan 2, 2010 | 07:39 AM
xatomisk's Avatar
what size spacers should I get if I'm on Tein SS with stock wheels?
Old Jan 2, 2010 | 03:14 PM
Yanki01's Avatar
lol, read from post #28 on.
Old Jan 2, 2010 | 10:08 PM
lol
