Mixed opinions about changing ATF
Old Jan 3, 2010 | 08:49 PM
SoleLaced's Avatar
Default Mixed opinions about changing ATF
So Ive been getting weird opinions in replacing my ATF.
I read the DIY in the tech section about changing tranny fluid and I thought I had the right idea. Apparently, 05-06 tc's take type-IV fluid and 07-08 take type WS fluid? Is that right?
I ran out to the garage to check my dipstick incase it stated which type to take. There was a label on my "black" dipstick that stated that the "ATF does not need to be changed under normal driving conditions. Refer to owners manual for more information." I noticed my other tc friends have a yellow dipstick. Maybe its different in the years?
My manual stated that the ATF needed to be changed at 30k. That contradicted what that label on the dipstick said. Im pretty confused.
I drive an 07 with about 40K miles.
Who has the right information on what I should do?
Old Jan 3, 2010 | 09:41 PM
my06tc's Avatar
go by what your manual indicates.......if you havent changed your ATF yet at the recommended mileage then i would do so....depending on how often you drive the car.....if you bought the car brand new and you hit the 30k mile mark and did alot of driving then yea i would do it.....everyone does theres at different times......as far as kind of fluid not to sure everyone has there favorites......
Old Jan 4, 2010 | 12:18 AM
cmcpride's Avatar
red dip stick handle will be TI4, replace every 60k, black dip stick handle WS no need to replace fluids. manual trans every 30k..
Old Jan 4, 2010 | 12:56 AM
SoleLaced's Avatar
yeah I have black dipstick so I suppose I dont need to change it?
My manual says to change it every 30k though. Id rather just change it to be safe. Are there any fluids that are WS in stores that I can replace it with?
Old Jan 4, 2010 | 02:26 AM
ESEMRFOZZ13's Avatar
dealer checked, and advised it was good as gold at 50k. so no need to change still for me.
Old Jan 4, 2010 | 02:44 AM
3min3m2's Avatar
Funny. My Red handle said check level, and no need to replace. But since Im at 70k...might as well
You guys get flushed or just drain pan and change 4 Qts?
Old Jan 6, 2010 | 01:04 AM
my06tc's Avatar
i change mind a few times only cause i have a 5 speed and also some oils make it easier to go into gears then others do
Old Jan 7, 2010 | 06:16 PM
silvertcgirl09's Avatar
Team ScionTific
new ATF is better than old ATF
Old Jan 7, 2010 | 09:40 PM
Hix's Avatar
Hix
Here ya go check out this link for all the oil specs.
http://www.amsoil.com/mygarage/vehic...007+SCION+TC+4
RY_TC07
Jul 18, 2017 05:18 PM
elwaylite
Apr 30, 2015 02:31 PM
kleecker
Apr 4, 2015 02:37 PM
mrsocks
Jan 20, 2015 01:29 PM
06ScionTc5sp1
18
Dec 21, 2014 07:21 AM
