Camber kit for 08 tc?
Old Feb 14, 2010 | 10:49 PM
Philip-tc's Avatar
Default Camber kit for 08 tc?
Im about to drop my car on s-techs, and i dont want my tires to mess up. so im thinking of getting a camber kit. do i need a camber kit for the front or rear? or both? thanks
Old Feb 14, 2010 | 11:19 PM
ack154's Avatar
Read: https://www.scionlife.com/forums/scion-tc-1g-suspension-handling-1615/suspension-faq-read-first-47974/
Old Feb 15, 2010 | 03:37 AM
Philip-tc's Avatar
oh so the fronts are only bolts? and the rear is the camber arm?
Old Feb 15, 2010 | 03:59 AM
americandesi's Avatar
you shouldn't need a camber kit. Just get an alignment.
Old Feb 15, 2010 | 11:24 AM
ack154's Avatar
This is kind of what I was hoping you'd get out of that.
Old Feb 15, 2010 | 06:17 PM
RoboCop's Avatar
I would say it depends. I know when I dropped my car on coilovers, most everything fixed itself with an alignment but my front camber is still off. Both tires want to lean to the right. It's very minimal, but it's not perfect.
Old Feb 15, 2010 | 06:27 PM
ack154's Avatar
Well another thing to understand is that camber alone will not eat your tires (unless it is EXTREME camber ... like more than -3° or something).
It is key that the rest of the alignment options are in spec (mostly Toe). If you have a little neg camber with a really bad toe setting ... THAT will destroy your tires faster than any neg camber alone will do.
Old Feb 15, 2010 | 06:35 PM
RoboCop's Avatar
Agreed with ack, but like in my case, my car will always want to pull right now, but it's only like .1* on each side leaning to the right.
Old Feb 15, 2010 | 09:20 PM
Philip-tc's Avatar
im gonna get a camber kit just incase
Old Feb 21, 2010 | 02:53 AM
Rexpelagi's Avatar
For whatever it's worth, I run -2° camber and 0 toe in the front along with -1.3° camber and slight toe-out in the rear on stock suspension. I have only been using these settings for about 8 months but I haven't noticed any abnormal wear with these settings.
Old Feb 28, 2010 | 04:25 AM
etsnet's Avatar
So can the toe be adjusted without a camber kit? I'm on stechs on my tC and been for a while and I just noticed my tires are wearing already after about 8 months. They seem to be worn on the front outside of the tire. I also have some suspicion that it's rubbing but I haven't really got under there and checked.
Old Feb 28, 2010 | 05:34 AM
Rexpelagi's Avatar
Yes, toe can be adjusted without a camber kit. However, if you are wearing on the outside of the tires with negative camber you must have some rubbing, because I don't think tires with negative camber should wear the outsides before the insides.
jcraff3
Feb 20, 2015 11:41 PM
kleecker
Jan 2, 2015 08:09 PM
Alvie
Dec 12, 2014 05:04 AM
Mr_Magu
Jan 17, 2004 05:21 AM
randode
10
Dec 11, 2003 06:05 PM
