Help needed on clutch install
Old Feb 28, 2010 | 10:27 PM
cburglb34's Avatar
Default Help needed on clutch install
ok so im in the process of replacing my clutch and i just cant manage to get the passenger axel out... i undid the 2 bolt son the driveshaft case and still notihng so i then unbolted the 3 bolts holding it to the block and stikk nothing i need help lol
Old Mar 1, 2010 | 01:12 AM
johnhawkins's Avatar
Took me about 6 hours of prying, thinking, prying, crying, thinking, prying. PITA - just keep trying....get a prybar if you dont have one.
Old Mar 1, 2010 | 01:45 AM
cburglb34's Avatar
i was using a pry bar but me n my friend came up with the clever idea of saying ____ this and unbolted the transmission and pryed the transmission out leaving the axel in spot......(I HIGHLY RECCOMEND IT HAHAHA EASY AS PIE)
Old Mar 1, 2010 | 03:45 AM
Carlanga's Avatar
good thing u got it out. Next time tap out where u disconnected the two bolts towards the passenger side with a pry bar and a rubber mallet. Or just the pry bar right where it meets the tranny. When putting them back in, be careful not to break the lip on the rubber seal.
Old Mar 1, 2010 | 03:47 AM
Carlanga's Avatar
which clutch did u ended up getting?
Old Mar 1, 2010 | 03:59 AM
TCpete's Avatar
passenger side axle removal..
-2 bolts on the axle remove on the bracket connected to the block.. its not necessary to remove the bracket from the block... only the 2 14mm bolts parallel to the axles
- hammer lightly tap on the axle cyclinder connected to the trans this will loosed it just a bit
- tug lightly on the metal axle to pull out closest to the trans and you should be done... takes 5 minutes of work
you can also use a tire iron and wedge it inbetween the trans and the black axle cylinder to pry off the axle or you can use a tire iron and use the L groves on the axle and hammer outwards to the wheel as leverage and should work also
should take 5-10 min for this operation. very simple and easy
Old Mar 1, 2010 | 04:01 AM
TCpete's Avatar
you should not do this at all
this is why people pass. side axle seals break and should never be done
the correct way is to fully take the axle out which makes it much easier to mount back onto the motor vs. leaving the axle in place where you need to be more precise and takes muuuch longer and much more work to get it on.
Old Mar 1, 2010 | 01:40 PM
cburglb34's Avatar
f1 racing stage 3 and i bought an oem TOB
yes pete this i was aware of that so we took extra care of it
yhwhdesign
10
Feb 6, 2015 05:00 AM
Xaphoon
Jan 17, 2015 02:12 AM
rancur3p1c
Dec 19, 2014 04:30 PM
XB_2
Nov 23, 2014 02:48 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
