built head
Old Mar 2, 2010 | 02:18 AM
game-over's Avatar
Default built head
ok... now i have searched for BUILT HEADS..
and i'm not getting anything constuctive...
so please help me out with finding a old thread or giving info for a new built head thread....
so here it is...
i want to start building my motor so im a year or two i can reach the 450-500-whp...
i have a particular head in mind. but just want a feel for what else is out there, ptuning and dezod both offer heads..
and another question.. if i buy a head now and dont install it for a year or 2 will it still be fine...
again if there are threads on thist then please post links
if not please feel free to answer and ask questions thru out...
i'm just tryn to be safe..
Old Mar 2, 2010 | 02:34 AM
trd07tc's Avatar
a piece of aluminum wont "go bad"
What are you really trying to ask? Your question is too general
Old Mar 2, 2010 | 02:43 AM
game-over's Avatar
I was told if it sat it could rust?
I know it's not like bread. Lol
is a built head over kill, can I run my fic with a built head,
port and polish worth the money?
I don't know anything about it. And I don't see many threads with people building there motors along with the head.
One of the only reasons why I want it are...
I want more of a rpm range. And gain some hp.
Old Mar 2, 2010 | 03:52 AM
Twilight2ner's Avatar
Tuning options shouldn't have anything to do with the head. You might need another tuning session since a done-up cylinder head could increase your boost a few PSI (no joke) though.
A port and polish is a great way to make more power. I don't see the point in you dropping $1000-1500 on a head now and then wait a year or two to install it, however. It's more worthwhile to set the money aside and earn even a few bucks interest on it than just let a cylinder head sitting around (covered and with a little oil on it to prevent that corrosion you're talking about).
Old Mar 2, 2010 | 04:25 AM
trd07tc's Avatar
Aluminum doesnt rust.
Built head can never be "overkill"
Actually if you have a FIC dont bother... Because its not possible to increase the redline
Get a PNP and a set of Valve Springs/Retainers with an ultimate or standalone and enjoy
Also I would NOT try and run aftermarket cams with a piggyback
Old Mar 2, 2010 | 04:45 AM
BlackKnight's Avatar
Music City Scions
I would just put the money in a savings account until you have the cash for the full setup or what you want to do. Problem with buying the parts now and it sitting is the seals could dry rot, not saying they will but its always a possibility. If you buy the head now and its sits I would be concerned with the valve seals dry rotting.
Old Mar 2, 2010 | 04:53 AM
game-over's Avatar
^^^^^^^ that's what I am concerned about.
Not really rusting but corrosion.
I'm only thinking about this because droping $8000-$10000 all at once can be sickning
Old Mar 2, 2010 | 04:57 AM
game-over's Avatar
Trd. I do want to get the greddy ultimate. For the built in two step and so you can control the red line.
Pa has strict emissions and I want my car to be able to pass, or I would use the ems, or the hydra.
Old Mar 2, 2010 | 04:58 AM
game-over's Avatar
Thanks for the thoughts twilight
Old Mar 2, 2010 | 05:33 AM
rhythmnsmoke's Avatar
Music City Scions
You can pass with the ultimate, you can't pas with a standalone though.
Old Mar 2, 2010 | 01:39 PM
paul_dezod's Avatar
Scionetics
KAD
APR is another option.
http://www.dezod.com/pd_apr.cfm
Old Mar 2, 2010 | 02:50 PM
That's good to know. I was wondering if the APR would be able to pass emissions and such.
Old Mar 2, 2010 | 04:32 PM
j3st3r's Avatar
Music City Scions
Unless you use the setup from Lethal Motorsports
Old Mar 2, 2010 | 06:39 PM
Ace83's Avatar
Ronin Scion
^^ which setup is that? are you saying you pass emission on your hydra? thats crazy
Old Mar 2, 2010 | 06:55 PM
bdis3's Avatar
Why not? tuning it isnt hard, and the increased flow over stock will only improve power. I dont understand your statement.
Old Mar 2, 2010 | 08:52 PM
paul_dezod's Avatar
Scionetics
KAD
It's an "in-line" ECU that works similar to a programmable TRD reflash. You can not enter excessively rich VAC AFRs or it will trigger codes for system too rich or lean. It works in harmony with the stock ECU quite well.
I have been playing with this unit for 10 months. If you set it up right, you can get decent fuel economy in cruise for sure. Better than with any piggyback I have played with. The control is nice and simple! See this thread (esp Page 7)
https://www.scionlife.com/forums/sho...d.php?t=181043
This offers 2Step launch control, an engine guardian mode, MAF rescaling, ignition control (using stock knock control), fuel delivery (using stock fuel delivery).....It's expensive for sure, but has some great usability. Drive-ability, is like a crisp tuned standalone or a stock turbo car.
Old Mar 2, 2010 | 09:25 PM
BOOSTit06's Avatar
pretty sure valves,springs etc can corrode if not stored properly
Old Mar 3, 2010 | 02:41 AM
t_urbo_C_harged's Avatar
Built head is only overkill if your goals were < 350whp, which yours are not.
Port is definitely worth it. Polish is debatable as some builders will state that it will carbon up quickly anyway. The way I see it is while you are there, why not! Plus if you run water/meth, that will help keep the motor carbon free.
I would wait to build it as well. If it was built with assembly lube, well that lube isn't meant to last very long. You could build it and oil it every once in a while, but that would be a waste in my opinion. I would just do the entire motor at once, that way there aren't any worries!
steeze69
May 24, 2021 02:57 AM
mischman
Sep 15, 2015 03:38 PM
BlingSlade
Sep 5, 2015 08:52 AM
umnitza
Sep 1, 2015 08:06 PM
sethmskinner
Aug 4, 2015 02:38 AM
