Faulty master cylinder?
Old Mar 24, 2010 | 04:40 AM
matt's Avatar
Default Faulty master cylinder?
I've been having some problems with my brakes lately. It all started after I took my car to the canyons a little while ago. I overheated the fluid in the lines, so i purged all the burnt fluid out by bleeding it manually. The pedal was going to the floor when depressed, so I bled my brakes, but it didn't get any better.
I installed a set of Goodridge SS brake lines, but after installing them and bleeding the system with a vacuum bleeder, the pedal goes to the floor. My mechanic says it is a bypassing master cylinder and needs to be replaced.
My car is just under 4 years old and has 16k miles on it - just out of warranty. I took it back to the stealership and they extorted 50 bucks out of me to tell me nothing was wrong.
Has anyone else had this problem?
Old Mar 27, 2010 | 06:58 AM
scrappytk's Avatar
usually master cylinders last up to 10 years before they start to get bad. if you replace the lines and the issue still remains the same it's most likely the Master Cylinder itself, is there any leaks around the MC? I know the new Dual MC can't be open and repaired like the older ones they have to be fully replaced. did you adjust the push rod because thats a possible in the issue causing tho interfere with the inlet and compensation ports, if you do have a leak then your secondary seal is broken.
Old Mar 27, 2010 | 06:29 PM
sciontc_mich's Avatar
take a look at the check valve on the master cylinder booster. it's on the lower left, about the 7oclock position. if that was bad you'd possible have a vacuum leak.
yhwhdesign
Jun 11, 2021 03:34 PM
steeze69
May 24, 2021 02:57 AM
carbinefreak
Sep 24, 2015 02:06 AM
Mjdavis1994
Jul 18, 2015 04:29 AM
