Both headlights out - OEM
Old Mar 24, 2010 | 11:31 PM
mclark999's Avatar
Default Both headlights out - OEM
2005 Xb
Out for a drive the other night and both headlights went out. I smelled something like overheated engine right before. That smell has been coming on and off for a bit.
I checked the two fuses in engine bay for right and left headlights. They are both okay. I replaced the relay for the headlights. Still no lights.
Any other ideas?
Regarding the relay, I wasn't sure I replaced the right one. My relays are not in the exact spot that the wiring diagram shows. It shows on the side of the relay block under the dash. My relays are on the front of the wiring block just above the other fuses? Am I getting the wrong one?
Old Mar 25, 2010 | 01:23 AM
Frizz's Avatar
Team ScionTific
Did you check the bulbs....?
Old Mar 25, 2010 | 02:51 AM
tc-guy's Avatar
most likely the bulbs or the connectors itself.
Old Mar 26, 2010 | 02:35 PM
mclark999's Avatar
I don't think it is likely that both high beams and low beams would all go out at the same time, especially since they are fused separately. Perhaps a connector that runs through both circuits.
Old Apr 21, 2010 | 09:12 PM
FL21289's Avatar
Happened to be before, don't look at the fuses you circled the real fuse for it is the little red ones that say "10" on them, most likely the bottom right of your picture taken. This happened to me before twice already. Easy fix.
bluemex
Jun 16, 2015 03:22 AM
mischman
Mar 31, 2015 03:16 AM
scsteven
Jan 25, 2015 01:06 AM
Beesh
Jan 9, 2015 06:30 PM
TheTripleC
Jan 4, 2015 06:46 PM
