07 scion tc AEM FIC problem
Old Apr 4, 2010 | 02:08 PM
boardriderxxx's Avatar
Default 07 scion tc AEM FIC problem
I have the aem fic in my car N/A till next weekend. All my maps are at 0 so the fic shouldnt be doing anything. But my idle is off and it 3000rpm to 3500rpm it just stumbles.
Old Apr 5, 2010 | 04:32 PM
skinnayyy's Avatar
Team Scionara
change the O2 map to voltage and set it at about 3.2 for everything. that's what i was told to do, and the injector response time should be about 600 us
Old Apr 5, 2010 | 04:52 PM
CarbonXe's Avatar
Have you calibrated the TPS yet?
Old Apr 5, 2010 | 07:10 PM
Yea i went through all the cals.
Old Apr 5, 2010 | 07:25 PM
CarbonXe's Avatar
Check connections then. If all the maps are 0, then the F/IC shouldn't be doing anything at all. I ran for a while with my F/IC hooked up and all blank maps.
Was it a plug and play harness or did you do the wiring yourself?
Old Apr 5, 2010 | 08:07 PM
Blue_TC_Man's Avatar
I had the same problem. Boomslang gave me a bad harness I shipped it back and they sent me a fixed one. The crank in and crank out wires are flipped (at least mine were)
Old Apr 5, 2010 | 09:41 PM
Yea it is a Boomslang harness i thought that was the problem the whole time. Cause your right all maps 0 the fic should do nothing. It also did throw the check engine light.
Old Apr 6, 2010 | 12:32 AM
skinnayyy's Avatar
Team Scionara
yeah mine ran like crap even with the O2 voltages, it sputtered at idle and threw misfire codes, so i unplugged it and now everything runs right.
Old Apr 6, 2010 | 02:02 AM
crush02342002's Avatar
iv done the same thing on my 07 and it ran great for a day then turned to poop, it was the o2 map. I had heard some say they ran a compleatly zero'd out cal with everything set to percentage but in my case and a few others it didnt work out. check the code and im sure it will have something to do with the o2.
Old Apr 6, 2010 | 02:05 AM
did you have the other maps set to percentage and zero'd?
Old Apr 7, 2010 | 05:18 PM
skinnayyy's Avatar
Team Scionara
yeah i had everything on percentage and 0 except the O2 was voltage set to 3.2, and 3.13 and both still ran like crap. so i just said whatever and unplugged it. after each time i plugged it in i let it idle for a while too and still no go.
Old Apr 7, 2010 | 09:49 PM
any codes? newer boomslang harness have a 10kohm resistor on the o2 leads, that would be something to look into.
here it is on my harness (i peeled off the heatshrink that hides it but should give you an idea)
Old Apr 14, 2010 | 03:00 PM
Yea there is no 10k resistor on the O2 sensor wire. Maybe ill try that before the turbo install this weekend.
Old Apr 14, 2010 | 04:26 PM
cburglb34's Avatar
NO! u dont want the 10kohm on the o2 crush was just telling u if its there than thats your problem.... likely u might need resistors on crank n cam
Old Apr 14, 2010 | 05:28 PM
^^what he said...lol
Old Apr 15, 2010 | 01:38 PM
The harness does have the reisitors across the crank and cam none at the O2 wire. I heard so times this things are wired worng. Anyone ever here of that.
Old Apr 15, 2010 | 01:42 PM
do me a favor and get a scangauge (barrow one) find out if your in open loop at idle.
Old Apr 15, 2010 | 01:45 PM
some have said that they have had miswired harnesses but it wasnt many. some have even said they have had issues with having resistors on the cam or crank (dont remember which ones they had an issue with). so far iv never had an issue with resistors on the cam or crank...only on the o2 is what iv had an issue with.
helloninja
Mar 19, 2018 04:50 AM
AbsoluteRedtC
Dec 31, 2014 06:18 PM
minter66
Dec 15, 2014 01:45 PM
kagero79
10
Dec 24, 2003 04:23 AM
EV_AIC-xB
11
Oct 10, 2003 07:28 AM
