Gauging Interest: Adjustable Throttle Controller Group Buy
Old Apr 21, 2010 | 07:02 PM
GrnBrownies's Avatar
Default Gauging Interest: Adjustable Throttle Controller Group Buy
Just letting you guys know, we're seeing if there's enough interest to run a second group buy of the Adjustable Throttle Control!
What is an adjustable throttle controller?
This kit functions like the Blitz electronic throttle controller but w/ more adjustable steps to serve different conditions from drag racing, drifting to hyper-mile cruising. And our kit is NOT a bolt-on that will make 20HP in 30 minutes. It's a kit that will manipulate the throttle regulator to response faster or slower at user's desire.
Electronic Throttle Controller Features:
1. 12 step adjustment switch
2. Reverse cancel wire
3. Special wire connector for Subaru Legacy
4. Installation Guide
5. 1 year product warranty for replacement
6. Built-in safety bypass switch. No worry if hardware failure occurs.
This kit is plug-n-play, but if it is used w/ Scan Gauge or other OBD port connected device, you will need to buy a cable splitter for it to work properly.
GI thread: https://www.scionlife.com/forums/sho...d.php?t=185548
Old May 27, 2010 | 10:34 PM
wingleung9's Avatar
will this kit damage the car computer or senor by sucking more air?
Old May 28, 2010 | 04:52 AM
xDTool's Avatar
quite simply, no. this doesnt make you run more rich or more lean, or add any "power". all this does is improve the electronic response of the throttle to provide for less acceleration lag.
Old May 28, 2010 | 05:00 AM
twpanson's Avatar
No, the kit won't damage the ECU or sensor. The kit doesn't change the volume of air being sucked in.
What it does is to improve/change the velocity not the capacity of air being sucked through throttle body.
That way, you have the opportunity to change the mode from Sports (suck in air faster) to Eco (slower) in order to cope w/ different driving condition you might encounter.
Sincerely,
NonStopTuning
Jun 29, 2015 07:42 PM
NonStopTuning
Jan 20, 2015 05:20 AM
arinvolvo
24
Nov 2, 2003 05:30 AM
GreatWhitexA
32
Oct 18, 2003 05:40 AM
scionlife
Apr 16, 2003 05:13 PM
