Turbo Manifold
Old May 8, 2010 | 02:06 PM
RacerFreakXXX's Avatar
Default Turbo Manifold
I'm looking for a turbo manifold for my Yaris, 1NZ-FE. I'm considering an ebay turbo manifold, they look the same as all the other log manifolds. Has any one here had actual experience with an ebay turbo manifold?
Old May 8, 2010 | 04:41 PM
brainneeded_'s Avatar
theres a shop that sell a blank flange for the exhaust manifold, you can have a shop weld up a turbo manifold.
Old May 15, 2010 | 07:12 PM
Fatkid's Avatar
if its the same as the xb1 i have one that will fit
Old May 18, 2010 | 12:02 AM
silvrtc300's Avatar
I have one. It's a revhard casted one. $250 shipped hit me back up. I have a bunch of stuff. let me know if you are interested. P-N-P head (* $300 ) and a few other parts.. need a short block i got one of those too (* $ 500) {got for a build}, Fuel rail(* $50). Crank pulley (* Light crank pully - $45) .. all this was on my echo. willing to let all this stuff to go at very low cost.
Old May 18, 2010 | 03:20 AM
ScionCREW's Avatar
www.MicroImageOnline.com he sould have them in stock. here is the link to his web. http://www.microimageonline.com/foru...s-are-in-stock
Old May 30, 2010 | 08:36 PM
1FastXA's Avatar
I have a 1NZFE turbo manifold that was used for less than two weeks before I took my turbo kit off. I'll sell it for $400 shipped to 48 states excluding Hawaii and Alaska. Please message me if your still interested in a manifold.
Old Jun 4, 2010 | 10:53 AM
speedismyneed's Avatar
If you manage to find any of these second hand then I'll hate you forever! I've been looking for ages and have struggled, best of luck to you!
Old Jun 16, 2010 | 05:58 PM
FOUR T2's Avatar
What kind of fuel rail is it? Do you have any injectors too?
Old Jun 16, 2010 | 06:11 PM
FOUR T2's Avatar
Also, to answer the topic question: I have one of the ebay cast manis with a T25 flange and other than being the smallest one I have ever seen it is well crafted. It came with the exhaust-side gasket, but does not come with the turbo-side gasket. I degreased it, painted and cured it with high temperature paint as soon as I got it. I also am having a friend port and polish it as it is also a little rough. Another small downside is that the bolt holes on the mani are threaded as are the ones on my turbo, but that is easily solved by drilling out the holes on the turbo. All in all a good purchase for the price...160 shipped. Another bonus is that the flange is a bit offset to the side with more room and it also points up. This should prove to make piping and fabricating a downpipe much easier. As you may have gathered it is not on the car yet, but should go on with ease. Hope this helps answer your question...
Old Jun 16, 2010 | 07:55 PM
vettereddie's Avatar
Check Dezod. $250, welded tube steel, not cast iron, looks great. I have it for the 365Motorwerks kit (no longer in production from lack of demand). Can't garuntee it will clear the Yaris firewall, but uses a standard T25 flange, internal wastegate setup.
http://www.dezod.com/pd-1nzfe-turbo-manifold.cfm
Old Jun 16, 2010 | 11:36 PM
I've found what I am looking for, thanks for the suggestions and the good info.
Old Jun 23, 2010 | 01:05 AM
paul_dezod's Avatar
Scionetics
KAD
Thanks for pointing that out. We are discontinuing them and need to move them out of inventory.
tckid21
Jan 9, 2016 09:19 PM
carbinefreak
Scion tC 2G Forced Induction
Sep 27, 2015 09:36 AM
Scionxa180
Sep 24, 2015 03:51 AM
brett561tc
Sep 15, 2015 06:33 AM
Angelj85
Aug 18, 2015 01:27 AM
