Turbo Manifold
I'm looking for a turbo manifold for my Yaris, 1NZ-FE. I'm considering an ebay turbo manifold, they look the same as all the other log manifolds. Has any one here had actual experience with an ebay turbo manifold?
I have one. It's a revhard casted one. $250 shipped hit me back up. I have a bunch of stuff. let me know if you are interested. P-N-P head (* $300 ) and a few other parts.. need a short block i got one of those too (* $ 500) {got for a build}, Fuel rail(* $50). Crank pulley (* Light crank pully - $45) .. all this was on my echo. willing to let all this stuff to go at very low cost.
www.MicroImageOnline.com he sould have them in stock. here is the link to his web. http://www.microimageonline.com/foru...s-are-in-stock
Also, to answer the topic question: I have one of the ebay cast manis with a T25 flange and other than being the smallest one I have ever seen it is well crafted. It came with the exhaust-side gasket, but does not come with the turbo-side gasket. I degreased it, painted and cured it with high temperature paint as soon as I got it. I also am having a friend port and polish it as it is also a little rough. Another small downside is that the bolt holes on the mani are threaded as are the ones on my turbo, but that is easily solved by drilling out the holes on the turbo. All in all a good purchase for the price...160 shipped. Another bonus is that the flange is a bit offset to the side with more room and it also points up. This should prove to make piping and fabricating a downpipe much easier. As you may have gathered it is not on the car yet, but should go on with ease. Hope this helps answer your question...
Check Dezod. $250, welded tube steel, not cast iron, looks great. I have it for the 365Motorwerks kit (no longer in production from lack of demand). Can't garuntee it will clear the Yaris firewall, but uses a standard T25 flange, internal wastegate setup.
http://www.dezod.com/pd-1nzfe-turbo-manifold.cfm
Scionxa180
Sep 24, 2015 03:51 AM
