Wierd issue when under boost.
Old May 15, 2010 | 05:54 PM
FLIN-SCION's Avatar
Default Wierd issue when under boost.
Ok I have this issue, when I get on the go pedal my "brake" light comes on, like I'm pulling my ebrake. lol
Any suggestions? Like a loose cable or something?
Old May 15, 2010 | 05:55 PM
Tc4Eva's Avatar
Team ScionTific
Your pads are probably worn out. Check them out and check the brake fluid level as well. Its probably time for new front pads at least.
Old May 15, 2010 | 05:57 PM
brett561tc's Avatar
your brake fluid is low.
Old May 15, 2010 | 06:58 PM
yamaha16bw's Avatar
Yup happened to me when I did my brake upgrade like a month ago. Top off the fluid and your good.
Old May 15, 2010 | 11:08 PM
xtcO7's Avatar
I got. The same problem. I'll check the oil fluid too
Old May 16, 2010 | 01:49 AM
FLIN-SCION's Avatar
none of that is true. pads are fine. fluid is fine. i think its got to do with the e-brake somehow.
Old May 16, 2010 | 01:56 AM
brett561tc's Avatar
put in more fluid and the light will stop coming on during acceleration. i promise.
Old May 16, 2010 | 02:23 AM
rangerryda's Avatar
QFT
Old May 16, 2010 | 04:27 PM
speedy000's Avatar
i had this exact problem even b4 i was boosted!!!!!
you ebrake is loose and under heavy acceleration the lil sensor kicks back an thinks your pullling the ebrake.
if you dont belive me try tugging on the ebrake just a little with out it clicking in the light will turn on instantly at the sign of your ebrake moving.
just take the cover off and tighten it and problem fixed.
csmonte
Jun 26, 2015 08:44 PM
nazblue5807
Apr 11, 2015 12:20 AM
shawnb41
Jan 28, 2015 05:17 AM
gulp35
Apr 6, 2004 05:26 AM
DibujoB
Mar 10, 2004 02:13 PM
