A little change in ride height
OK, so I added a little work to the suspension this time around.
Added this big piece of aluminium that bolts to the underside in place of the tow hook.
And it has a few things bolted to it.
Now it goes up.
And down.
Shots of the front and rear tires tucked.
And a shot of the clearence underneath.
Now it goes up.
And down.
It's mostly the Air Lift Easy Street kit with the digital controller. I changed out the tank for an AVS aluminium unit that would fit under the car. It's only 7" by 28" and is a side mount unit so it take up very little space. Couldn't take up any room in the hatch as I have a wood and aluminium floor and my stereo amps and processors mounted under it. I also added the .100" aluminium mounting plate so that I could wire and mount everything on the work bench and then bolt it into place.
mrsocks
Jan 20, 2015 01:29 PM
fluxingnation
Dec 26, 2014 04:28 PM
