Painting SCION emblem on my tC
Old May 30, 2010 | 05:24 PM
TCFrankiw's Avatar
Default Painting SCION emblem on my tC
This probably has been asked a million times but I Searched the threads and couldn't find anything.
I debaged my tC and now I'm planing to paint the emblems Black, what paint should I use, should I use primer and sand it too???
___
Old May 30, 2010 | 05:35 PM
tCtCtC's Avatar
Just be sure to sand it well. I used Rustoleum universal gloss black paint.
Old May 30, 2010 | 05:38 PM
TCFrankiw's Avatar
wich grit??
Old May 30, 2010 | 05:46 PM
tCtCtC's Avatar
I used 400
Old May 30, 2010 | 05:47 PM
TCFrankiw's Avatar
allright, thanks !
Old May 30, 2010 | 05:53 PM
tCtCtC's Avatar
No problem.
Old May 30, 2010 | 07:48 PM
badcooliebwoy's Avatar
Default krylon
Use Krylon Fusion paint for your emblem and all your plastic painting needs.
Old May 30, 2010 | 07:55 PM
1GreeKtC's Avatar
I used a spray on primer, no sanding required. Then I gave it a couple of layers of flat black spray. WIN.
Old May 30, 2010 | 08:22 PM
drivinkrn's Avatar
make sure you do more than one layer for sure~
Old May 30, 2010 | 09:28 PM
Vanacutt's Avatar
definitely more than one layer, it will look done but after in fully dries you may see some spotting, I learned the hard way and having to everything off again
Old May 31, 2010 | 01:22 AM
Chrisb319's Avatar
when we say multiple coats do light thin coats.
Old May 31, 2010 | 01:26 AM
Murphys_Law's Avatar
make sure you sand down in the lettering otherwise itll flake off inside the groves at the carwash
Old Jun 2, 2010 | 10:30 PM
rudymcskoody's Avatar
i just one some spray paint made for plastic. gave the whole grill a couple coats and it looks great. i've washed it a couple times, no chipping.
Old Jun 7, 2010 | 05:39 PM
TCFrankiw's Avatar
Default Painted emblems
so i finally painted the emblems, i used rustoleum satin black universal paint. i did a little wt sanding with a 400 grit sand paper. no primer or clear. here's some pics from my phone so the're pretty crappy
this is my first time doing this kind of mod so i think it came out pretty good
Old Jun 7, 2010 | 05:59 PM
Sciontistical_One's Avatar
it came out "okay", but it's not gonna last long without the right prep work... that means using primer... you should also use clear to protect it... if you're going for the flat black look, then use a flat clear, otherwise, they will chip after a few car washes no matter how careful you are... a lot of us have been there and done that... why would you want to make the same mistakes that some of us ( including myself) have made???
Old Jul 22, 2010 | 11:58 PM
TCFrankiw's Avatar
Bringing this thread from the dead... It's been almost 2 months since I painted and installed the emblems on my car. I followed your advices and added 4-5 coats of clear. Came out really nice, no peeling or cracking whatsoever. Thks
Old Aug 3, 2010 | 09:52 PM
Avodka14's Avatar
I took my tC emblem off and the protected paint under the emblem was significantly different from the surrounding paint. Guess that is expected after 5+ years of owning the car and realizing this is something I wanted to do. Sooooo, I am going to paint my emblems black like lots of peeps have done. Boredom can get a man in trouble.
ashtc2
Scion tC 2G Aero & Exterior
Mar 22, 2012 06:25 AM
insight420
Scion tC 1G Aero & Exterior
Oct 20, 2009 03:42 AM
Joyride
May 31, 2008 02:41 AM
JDMonkiTC
21
Jan 28, 2007 11:59 PM
KentTree
Jul 7, 2004 12:07 AM
